Plastic Rob 10 Posted August 8, 2014 Yes, that's right. I'll send them on after. Quote Share this post Link to post Share on other sites
Tigerfish 10 Posted August 8, 2014 Glad these haven't died out completely :) I'll wait for the smoked ones, any ideas how long they are likely to be? Quote Share this post Link to post Share on other sites
Torsten 0 Posted August 8, 2014 if you ever going to make some smoked cover for the fogs, so im in for a set still not sure about a smoked set for the headlight but how much shipped to germany ?? Quote Share this post Link to post Share on other sites
delfinis38 1 Posted August 8, 2014 Yes, that's right. I'll send them on after. thanks for conformation... Quote Share this post Link to post Share on other sites
VR6matty 0 Posted August 8, 2014 No fog covers as yet. I'm still unsure how to go about them yet. Have you considered making a lens that covers both fog and indicator then using some clear adhesive tabs to secure them to the front of the glass in the corners? Not sure if there is a better way to fix to the car but I was planning on doing something along these lines, I would be happy with anything really, just no more broken fogs or indicators! :D Quote Share this post Link to post Share on other sites
Plastic Rob 10 Posted August 8, 2014 Yes, if everyone is ok with that. I had a look at the fronts yesterday, there's a slight gap top and bottom, enough for a bent return and then maybe small adhesive pads on each end to secure. There is a slight curve end to end but I should be able to match that. Quote Share this post Link to post Share on other sites
clumpy1 11 Posted August 8, 2014 Yes, if everyone is ok with that. I had a look at the fronts yesterday, there's a slight gap top and bottom, enough for a bent return and then maybe small adhesive pads on each end to secure. There is a slight curve end to end but I should be able to match that. Sound's good that Rob Quote Share this post Link to post Share on other sites
dragon green 4 Posted August 8, 2014 Yes, if everyone is ok with that. I had a look at the fronts yesterday, there's a slight gap top and bottom, enough for a bent return and then maybe small adhesive pads on each end to secure. There is a slight curve end to end but I should be able to match that. X2 Quote Share this post Link to post Share on other sites
VR6matty 0 Posted August 8, 2014 Sounds like a good idea, look forward to seeing a finished product Quote Share this post Link to post Share on other sites
Ninjasean2005 10 Posted August 11, 2014 I would like to buy some fog and indicator lens protectors from you as soon as they are available Quote Share this post Link to post Share on other sites
Stone0311 0 Posted August 12, 2014 I would like to buy some fog and indicator lens protectors from you as soon as they are available 😊 Smoked ones for me 2 Quote Share this post Link to post Share on other sites
wazza 0 Posted August 15, 2014 Just received mine in the post today, can't wait to try them on the car, they look really good! Looking forward to the fogs now, keep up the good work! Waz Quote Share this post Link to post Share on other sites
Plastic Rob 10 Posted August 15, 2014 Spot on. Thanks waz. Gonna pin down getting them started next week. Quote Share this post Link to post Share on other sites
Tigerfish 10 Posted August 15, 2014 Any ideas on time frames for the smoked versions? Quote Share this post Link to post Share on other sites
Plastic Rob 10 Posted August 17, 2014 I'm sign fitting most of next week, smoked material is here and is the next job along with the fog/indicator covers. Quote Share this post Link to post Share on other sites
Tigerfish 10 Posted August 18, 2014 Cool, thanks. Desperate to get some protection on :) Quote Share this post Link to post Share on other sites
wazza 0 Posted October 15, 2014 Hi Rob, any word on the fog covers? Quote Share this post Link to post Share on other sites
Tigerfish 10 Posted November 18, 2014 Cool, thanks. Desperate to get some protection on :) Ended up snapping up a set of 2nd hand smoked ones now, but still interested in some smoked fog covers if you do get round to making them. Quote Share this post Link to post Share on other sites
delfinis38 1 Posted November 19, 2014 I'm still after some clear headlight protectors and also the indicator and fogs, rob not even selling them on eBay any more. He must have too much work on.... Quote Share this post Link to post Share on other sites
delfinis38 1 Posted December 1, 2014 I'm still after some clear headlight protectors and also the indicator and fogs, rob not even selling them on eBay any more. He must have too much work on.... Bump still after a set.... Anyone ? Quote Share this post Link to post Share on other sites
C5 OEM 0 Posted August 22, 2015 These still available....? Quote Share this post Link to post Share on other sites
delfinis38 1 Posted August 22, 2015 These still available....? I'm after fog and indicator covers too.. Quote Share this post Link to post Share on other sites
C5 OEM 0 Posted August 22, 2015 Just headlight for me..... Quote Share this post Link to post Share on other sites
spen 0 Posted August 31, 2015 Still available? I'll have headlight and fog please! Quote Share this post Link to post Share on other sites
clumpy1 11 Posted August 31, 2015 I have headlight covers on eBay if anyone is interested. Quote Share this post Link to post Share on other sites
