perky15 0 Posted December 18, 2013 finally got the cash cars booked in for a full respray :-) any thing you guys would suggest things to check etc ? Quote Share this post Link to post Share on other sites
seanl82 23 Posted December 18, 2013 Worth trying to get hold of a few things that'll probably fall to pieces on removal. Assuming its a windows out respray, you'll need both scraper seals (drivers side is obsolete iirc), wing mirror seals (also obsolete iirc), roof gutter plastics (obsolete) and door seals. As you can see, there may be a small problem with obtaining a few items! If you can do it yourself before taking it down, remove them yourself. BE VERY CAREFUL!!! Quote Share this post Link to post Share on other sites
BILLCOR 1 Posted December 18, 2013 Both scraper seals still available >> http://shop.volkswagen-classic-parts.de/vwcp/Scirocco-Corrado/Corrado/Karosserie/Aussen/Fensterschachtabdichtung.html Quote Share this post Link to post Share on other sites
Jim 2 Posted December 18, 2013 Get the windscreen out and check for rust around the A pillars / windscreen surround... makes sense to get that tackled whilst it's in! Quote Share this post Link to post Share on other sites
robrado974 1 Posted December 18, 2013 All of the above !! The pillars are not available any more either , the body shop should be able to sort them though if they are shot . Think I had one of the last sets . Quote Share this post Link to post Share on other sites
tman2714 0 Posted December 18, 2013 Sorry to crash the thread but would be interested to know how much roughly the respray is going to cost. Quote Share this post Link to post Share on other sites
shaft69 10 Posted December 18, 2013 How much they charging for full spray?? Getting mine done middle next year. Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted December 18, 2013 Cost of respray is piece of string varies from a few hundred to thousands so is pointless asking really. Things to do/ check: definitely screen out bag and label everything if stripping it yourself which I would also recommend! Plate surround, scrapers, roof trims, fogs indies and headlights make all the difference when paint is done. wheels in good order replace screws and bolts as said mirror gaskets and be careful not to over tighten take loads of pictures Quote Share this post Link to post Share on other sites
GrahamU 5 Posted December 18, 2013 All of the above !! The pillars are not available any more either , the body shop should be able to sort them though if they are shot . Think I had one of the last sets . A pillars are available from vw classic parts in the link a couple up, I bought one the other week for 50 euros Quote Share this post Link to post Share on other sites
robrado974 1 Posted December 18, 2013 I stand corrected , nice to know you can still get them if you need em Rob Quote Share this post Link to post Share on other sites
STU175 0 Posted December 18, 2013 one thing i forgot and regretted after i had full respray was not getting my arches rolled at the same time....i hadnt planned on fitting 9j alloys then! oh and get the seam on rear panel smoothed one thing i did plan and looks loads better i think? [ATTACH=CONFIG]76750[/ATTACH] Quote Share this post Link to post Share on other sites
shaft69 10 Posted December 18, 2013 Roof gutter trims are still available just ordered some from Germany with front screen trim kit too. Quote Share this post Link to post Share on other sites
leon263 0 Posted December 19, 2013 Door seals and wing mirror base gaskets all available from ARZ Tuning. Quote Share this post Link to post Share on other sites
perky15 0 Posted December 22, 2013 its going to be costing me around £1500 Cash ;-) a friend whos a professional sprayer has use of a heated booth and will do it for me. If I have the windscreen removed and the pillars are rusted is there any available of would it have to be welded etc? gutter trims are newish I removed them the other day to clean the car and I will try and remove scraper seals :-) don't want to roll arches or remove seams keep it as close to oem looking as possible Quote Share this post Link to post Share on other sites
Hofmiester 10 Posted December 22, 2013 Sorry to pipe in but where are the roof gutter trims available from in Germany? Thanks Quote Share this post Link to post Share on other sites
clumpy1 11 Posted December 22, 2013 Sorry to pipe in but where are the roof gutter trims available from in Germany? Thanks Yeah that would be good to know Quote Share this post Link to post Share on other sites
shaft69 10 Posted December 22, 2013 Arz tuning only have left in at moment tho. Quote Share this post Link to post Share on other sites
shaft69 10 Posted December 22, 2013 its going to be costing me around £1500 Cash ;-) a friend whos a professional sprayer has use of a heated booth and will do it for me. If I have the windscreen removed and the pillars are rusted is there any available of would it have to be welded etc? gutter trims are newish I removed them the other day to clean the car and I will try and remove scraper seals :-) don't want to roll arches or remove seams keep it as close to oem looking as possible Good price my respray poss be march/april need new engine and charger fitted 1st which I pick up on friday. Im in the trade so getting respray no problem just who gives me best price but know who I'll use in end I think. Quote Share this post Link to post Share on other sites
kdub 10 Posted December 23, 2013 If you do a lot of the prep yourself for a respray you can keep the costs down to around 14-1600 for a professional job. i,e, windows, interior out, lights off, spoiler/sunroof off, side bump strips, Bonnet & bumpers removed. Any rust defects welded/repaired and or panels replaced. To hand it over as is and want a window out, door shut respray with some minor repairs to rusty areas then expect to budget 2300-3000 again for a professional job and more if the restoration work is heavy. Also paint costs vary dramatically depending on the finish your after. So paints will cost you thousands before even starting. To get it done in someones workshop/home garage then I would be looking at paying no more than 1500 for a hand the keys over number. Quote Share this post Link to post Share on other sites
Hofmiester 10 Posted December 23, 2013 Also, to do pillars down only is cheaper. Mine had original paint on the roof and C pillars that was fine so only had it painted from bottom of windows down, and some cunning blending on the C pillars. Looks spot on. Ron Quote Share this post Link to post Share on other sites
shaft69 10 Posted December 23, 2013 My whole car needs doing been standing 5-6yrs no laquar on it. Solid no rust or dents. Pick engine/charger up friday for it. Quote Share this post Link to post Share on other sites
shaft69 10 Posted January 2, 2014 As it stands at moment removed front bumper today. Quote Share this post Link to post Share on other sites
perky15 0 Posted January 2, 2014 looks nice ill put pics up of mine tomoz before its going in at 4 and as some idiot scraped the side of it the other day I get a courtesy car :-) brand new Toyota gt86 until its done :-) Quote Share this post Link to post Share on other sites
Timbo 0 Posted January 3, 2014 That's some courtesy car! Quote Share this post Link to post Share on other sites
shaft69 10 Posted January 10, 2014 Finally got price for full spray inc door shuts and me stripping car all for £1400 cash. I know the lad and he's really good was head spraying at bmw dealer I worked at got his own body shop now. Going in start of march. Quote Share this post Link to post Share on other sites
