vw bobby 10 Posted December 20, 2013 Hi all, I need help, Basically I fitted a new dash in my corrado with a 1.8T engine conversion. The car use to start before and now it does not. It has a immobilizer and I have fitted everything back in as it was. All the lights come on, the fuel pump come on, but soon as I turn the key, it just goes dead. I tried changing the battery, as thought it may of been that and still nothing at all. Can someone please help on this? Cheers Bobby Quote Share this post Link to post Share on other sites
clumpy1 11 Posted December 20, 2013 Not a very easy problem to diagnose without actually seeing the car mate ;) Quote Share this post Link to post Share on other sites
vw bobby 10 Posted December 20, 2013 I know its a difficult one and just bloody annoying me now and getting frustrated. I think no power is getting to the starter? Quote Share this post Link to post Share on other sites
Rams 0 Posted December 20, 2013 What about the key and transponder box that's sits in the Rado dash? Quote Share this post Link to post Share on other sites
vw bobby 10 Posted December 20, 2013 That is still the original one that I was using initially, and never touched that Quote Share this post Link to post Share on other sites
MarkFoster 0 Posted December 21, 2013 Sounds like you've either dislodged or trapped and damaged a wire associated with the alarm/immobiliser... The tediousness of opening up the dash and checking cables for damage, and that they are still connected as the should be, awaits you I'm afraid fella. Quote Share this post Link to post Share on other sites
vw bobby 10 Posted December 21, 2013 Dam it, I had a feeling I will need to open the dash up again :( Quote Share this post Link to post Share on other sites
GrahamU 5 Posted December 21, 2013 measure the voltage at the starter, if no power there measure the voltage at the ignition switch if the fuel pump seems to work then you could be suffering from the traditional failed ignition switch Quote Share this post Link to post Share on other sites
