j_s14a 0 Posted May 19, 2014 I'm tempted to try and transplant the air con from my 16v into my VR6, but don't want to bite off more than I can chew. Have any regulars retrofitted this to their cars? And if so, would you mind giving me a breif rundown of what you did, and how long it took? My issue is that my VR6 is my daily, so don't really want it off the road for long. Cheers. :) Quote Share this post Link to post Share on other sites
Sean_Jaymo 0 Posted May 19, 2014 The only thing I would be concerned about is how the pipework gets into the heater box. When I fitted the later mk4 stuff, I had to cut another hole in the bulkhead. Not sure if this needs doing with the davia stuff? Quote Share this post Link to post Share on other sites
j_s14a 0 Posted May 19, 2014 The only thing I would be concerned about is how the pipework gets into the heater box. When I fitted the later mk4 stuff, I had to cut another hole in the bulkhead. Not sure if this needs doing with the davia stuff? Exactly my concern. Quote Share this post Link to post Share on other sites
Sean_Jaymo 0 Posted May 19, 2014 It's a bit of a job to do! Quote Share this post Link to post Share on other sites
j_s14a 0 Posted May 19, 2014 I gather. But I can Tackle it in bits, the critical part is getting all the interior stuff done quickly while the dash is out. And I have no idea of the layout at the moment. Quote Share this post Link to post Share on other sites
fla 9 Posted May 20, 2014 if you want to go through that process, why not fit climatronic instead? Just a thought. Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted May 20, 2014 I've removed a system before, not that hard to do. Fit the compressor to the aux belt area, the extra rad bolts onto existing rad along with another canister bit, then the pipework runs through the bulkhead to the heater box/fan area, and a switch needs fitting to the dashboard. Quote Share this post Link to post Share on other sites
j_s14a 0 Posted May 20, 2014 if you want to go through that process, why not fit climatronic instead? Just a thought. I've already got all the aircon parts from a 16v, and would also rather keep it original-ish. Quote Share this post Link to post Share on other sites
