4pekatt 10 Posted September 25, 2014 Hey guys! I want to order new headlight bulbs. I found some Nokya bulbs (7000k) that Im buying, but I dont know what wattages to look for. What is the OEM wires capable of handling? Both the H3 fogs and the H4 low/highs. (1990 G60) Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted September 25, 2014 OEM bulbs are 60/55W iirc, but stock loom can't really do them any justice. Aren't 7000K xenons? Best thing to do is uprate the loom and run some Osram Night Breakers. Quote Share this post Link to post Share on other sites
4pekatt 10 Posted September 25, 2014 I might just upgrade the loom and get the 90/100Watts then. Thanks! Not xenon, but PURE white/blue bulbs. Not the kind of cheap ebay crap :-) "Nokya Arctic White" - Google it :) Quote Share this post Link to post Share on other sites
science 0 Posted September 25, 2014 I don't think the standard reflectors can cope with 90/100w without melting. Quote Share this post Link to post Share on other sites
4pekatt 10 Posted September 25, 2014 No? Okay, i will not risk frying my reflectors. Thank you :-) Quote Share this post Link to post Share on other sites
davidwort 0 Posted September 25, 2014 In my experience 80/100w isn't needed and gives little more output than some good high light output 55/60s and a relay for at least dip beam even on cheap 55/60 standard bulbs (pref new) relaying up makes a huge difference, 80/100 def get very hot and the reflectors are only plastic Quote Share this post Link to post Share on other sites
Drucey 10 Posted September 25, 2014 What's the right night breakers with out melting anything? I have an update loom which is brilliant!! What would be the best/highest powered bulb? Quote Share this post Link to post Share on other sites
Tigerfish 10 Posted September 25, 2014 Osram Night Breaker Headlamp Bulb H4/472 60/55W are the ones I use with an upgraded loom, they work very well :) Quote Share this post Link to post Share on other sites
Graphite 0 Posted September 27, 2014 I ran 100w H4 bulbs in my headlights for some time and never had any problems but the reflectors were in perfect condition. If the reflectors have started breaking down on the surface then higher rated bulbs may just accelerate it. However 100w bulbs are illegal to use on the road as far as I am aware, something you might want to consider :) Quote Share this post Link to post Share on other sites
