science
Brake pedal switch adjustment?
I think my brake pedal switch (for the brake lights) has been pushed in while I had the servo out. It's now to short.
I presume it's a self adjusting ratchet as in other VWs.
Is there a way to reset or extend the switch?
It should just pull out, just checked on one I took off a golf vr, which I'm guessing is the same/very similar
Yes as above. Seems like it doesn't want to move but just pull it carefully. It's on a ratchet - type mechanism so a few clicks might be ok.
