Haarkon 10 Posted October 20, 2014 Does anyone know where i might be able to get a clutch master cylinder for a VR6 Storm, its the one with the ball end not the loop and has the inlet pipe pointed directly up and the outlet at 45° from that, looking from the rear. I have tried two VW specialist garages and a VW specialist parts shop and non have been able to source one. Failing finding a new replacement would anyone know of a company which reconditions old master cylinders. Appreciate any help on this. Thanks Quote Share this post Link to post Share on other sites
Jim 1 Posted October 20, 2014 Moving to Suppliers Forum.. Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted October 20, 2014 Can't remember who on here went through this recently. I want to change mine and have been told there is a different part to fit nowadays. Which also means changing a couple of other parts. Including the actual pedal. Quote Share this post Link to post Share on other sites
dragon green 4 Posted October 20, 2014 This company will recondition it http://www.pastparts.co.uk/ They will bore it out and line it with a stainless steel tube Or buy a newer clutch pedal(available from classic parts) And two little clips, If your interested in going this route,I'll post the part numbers,if it's my money,I'd re-con it They did my ABS mastercylinder Quote Share this post Link to post Share on other sites
Haarkon 10 Posted October 21, 2014 Thanks for the replies I think i'd rather go the recon route so i'll give pastparts ago Thanks again, appreciate it Quote Share this post Link to post Share on other sites
steveo29 0 Posted November 21, 2014 http://www.ebay.de/itm/KUPPLUNGSGEBERZYLINDER-KUPPLUNGSZYLINDER-GEBERZYLINDER-KUPPLUNG-GEBER-VW-/321544869195?pt=DE_Autoteile&fits=Model%3ACorrado&hash=item4add91554b plenty on ebay.de search "corrado Geberzylinder" Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted November 21, 2014 This company will recondition it http://www.pastparts.co.uk/ They will bore it out and line it with a stainless steel tube Or buy a newer clutch pedal(available from classic parts) And two little clips, If your interested in going this route,I'll post the part numbers,if it's my money,I'd re-con it They did my ABS mastercylinder MIght send them mine to do while it out :) Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted December 8, 2014 This company will recondition it http://www.pastparts.co.uk/ They will bore it out and line it with a stainless steel tube Or buy a newer clutch pedal(available from classic parts) And two little clips, If your interested in going this route,I'll post the part numbers,if it's my money,I'd re-con it They did my ABS mastercylinder Just rang these people, at first they said they don't do anything with ABS, which confused me, he said someone had rung about it recently. After i explained it he said they could do it and would be £80-100. Plus i have to post it to them. So expecting it to be at least £100. New one from VW is £176.40 Am not sure which to go with :lol: Quote Share this post Link to post Share on other sites
Dox 22 Posted December 8, 2014 (edited) http://catalogue.brake-eng.com/ They list all hydraulics, whether they stock them is a different matter http://www.brakesint.co.uk/bremtech_hydraulics.html Edited December 8, 2014 by Dox Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted December 8, 2014 Just looking around online and keep finding part no: 6Q0721388C Its for quite a list of cars, audi TT, Beetle, Jetta and looks just like the corrado one. Is there any reason i couldn't use one of these? Can get a decent sachs one for about £50 Quote Share this post Link to post Share on other sites
seanl82 23 Posted December 8, 2014 ECP list a Pagid one for VR6 for around £50 too. I couldn't say if its 100% correct, but likely if its the same for a number of models........ Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted December 8, 2014 Is that brake one? There is a pagid clutch one for £76, but pic looks wrong, just trying to check with them Quote Share this post Link to post Share on other sites
seanl82 23 Posted December 8, 2014 Yeah your right sorry! Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted December 8, 2014 Quite tempted to try the audi one. Going to compare them a bit more tomorrow. Quote Share this post Link to post Share on other sites
AngusL 10 Posted February 9, 2015 Hi Guys, A bit late on this but it doesn't seem to be resolved as yet... One of the first things I bought for my VR6 was this clutch master cylinder (copy and paste into your url as its not treating this as a hyperlink) :- http://www.ebay.co.uk/itm/CLUTCH-MASTER-CYLINDER-VW-CORRADO-2-0-2-9-PASSAT-35I-1-6-2-9-/381035761721?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item58b7805039 I have not fitted it yet but I know there are 3 subtle minor differences like the thick braided return pipe is pointing up at 45 degrees (no issue at all) and the high pressure pipe points straight out the back as opposed to up at what looks like a 45 degree angle. The other issue is the lack of thread to bolt it back into place - New bolts with nuts on the back would fix this. The Bentley manual shows nuts on the end of the USA LHD version - again no issue. I have got pics of the original in situ both inside at the pedal and outside where the pipes leave the unit. It looks like a minor task of carefully rotating the outlet high pressure pipe to match the new outlet. (I know - famous last words :-)) There looks to be a few cm to be gained by pulling the high pressure clutch pipe a little towards the master cylinder end to get more pipe length to allow me to rotate the high pressure outlet pipe to fit. So the question is - Am I missing something here because this is new and only £30.25 delivered ? It even came with the plastic clip that the ball end connects to the pedal with - this bit looks exactly the same as fitted into my vR6. Do you think I'm making extra work for myself? Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted February 9, 2015 Just to update what i ended up doing. I got my original refurbished by this company http://www.pastparts.co.uk/ Was very impressed with the speed of the service and the part came back looking like new. and fitted Did cost £100 though, but new one was over £170 Quote Share this post Link to post Share on other sites
dragon green 4 Posted February 9, 2015 That looks good Jim Quote Share this post Link to post Share on other sites
AngusL 10 Posted February 16, 2015 A quick update. I decided to fit the clutch master cylinder as detailed in my post above. It worked. Took a little over 45 mins but it's in and it went back in easier than the the old one came out. After bleeding the clutch now returns to its normal correct position where before the pedal was frequently sticking half way up. The slave cylinder is new and had been changed just before I got the car. Refer to my eBay link shown above. You do have to rotate the high pressure pipe but it's soft and easy to rotate. Make sure you get it pointing straight into the socket as the new cylinder body is aluminium - initially tighten it by hand So there is minimal risk of cross threading it. I started to tighten the high pressure pipe by hand before doing up the two main bolts so that the cylinder could move to match the high pressure pipe threads. The high pressure pipe was hand tightened to at least half it's thread easily The inlet thicker pipe pushes on easily. All things considered its an easy cheap replacement and the car does not need to be off the road for any length of time. I clamped off the supply rubber hose from the brake fluid reservoir I used a one way single person bleed valve. I did not have to remove the brake servo but I did use pan head bolts so an Allen key needs to be inserted to tighten up the nuts on the inside. I hope this helps someone It's not a hard task. Yours does look good Jim but I think new components and no downtime and a 30 pounds price tag I'm fairly happy with that. Getting the old ball end out of the pedal assembly now that is a real fiddly task. Look at the new one that comes with the cylinder to understand how it comes out. Please note mine is a 1995 Vr6 which does not have the loop connector to the pedal it has the ball end as per Jim's pic above. Quote Share this post Link to post Share on other sites
coullstar 0 Posted October 7, 2016 Just wondering if the current situation is still best to get the master cylinder refurbed by Pastparts? Im going new clutch so will fit slave and new master as well or refurb if that's better. Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted April 30, 2017 I have an update. My reconditioned one popped today and is dripping fluid out onto my foot. Only done about 3000miles with it. The fluid coming out is really rusty. Seems fine in the reservoir. Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted April 30, 2017 A quick update. I decided to fit the clutch master cylinder as detailed in my post above. It worked. Took a little over 45 mins but it's in and it went back in easier than the the old one came out. After bleeding the clutch now returns to its normal correct position where before the pedal was frequently sticking half way up. The slave cylinder is new and had been changed just before I got the car. Refer to my eBay link shown above. You do have to rotate the high pressure pipe but it's soft and easy to rotate. Make sure you get it pointing straight into the socket as the new cylinder body is aluminium - initially tighten it by hand So there is minimal risk of cross threading it. I started to tighten the high pressure pipe by hand before doing up the two main bolts so that the cylinder could move to match the high pressure pipe threads. The high pressure pipe was hand tightened to at least half it's thread easily The inlet thicker pipe pushes on easily. All things considered its an easy cheap replacement and the car does not need to be off the road for any length of time. I clamped off the supply rubber hose from the brake fluid reservoir I used a one way single person bleed valve. I did not have to remove the brake servo but I did use pan head bolts so an Allen key needs to be inserted to tighten up the nuts on the inside. I hope this helps someone It's not a hard task. Yours does look good Jim but I think new components and no downtime and a 30 pounds price tag I'm fairly happy with that. Getting the old ball end out of the pedal assembly now that is a real fiddly task. Look at the new one that comes with the cylinder to understand how it comes out. Please note mine is a 1995 Vr6 which does not have the loop connector to the pedal it has the ball end as per Jim's pic above. I will try one of these now. Thanks for the info. Very helpful. Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted May 4, 2017 Turned up today, i got a TRW one, was about £60 and came from France, am hoping it works, can't see why it wouldn't Quote Share this post Link to post Share on other sites
Geeba 0 Posted May 4, 2017 I'm about to start on an auto to manual conversion so will be needing these parts... years ago we just used to replace the seals in master cylinders... is this not possible with these ones? Quote Share this post Link to post Share on other sites
Dox 22 Posted May 4, 2017 I have an update. My reconditioned one popped today and is dripping fluid out onto my foot. Only done about 3000miles with it. The fluid coming out is really rusty. Seems fine in the reservoir. Do you spend your whole life walking under ladders? If it wasn't for bad luck you'd have no luck at all! Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted May 4, 2017 i know, its amazing. I really given up hope with using other people, things only seem to go right if i do everything myself. Quote Share this post Link to post Share on other sites
