stuarttaylor37 13 Posted November 26, 2014 Anybody used one of these? http://www.magneticoildrainplugs.co.uk/Technical_information_Magnetic_Oil_Drain_Plugs.html#.VHZjZNKsV8E What's the consensus, are they worthwhile or just a gimmick? Quote Share this post Link to post Share on other sites
davidwort 0 Posted November 27, 2014 you have an oil filer to do that job :) I think some gearbox plugs were magnetic though, might be of some use as that oil's not filtered Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted November 27, 2014 I bought one a few weeks back to put in my new engine build, can't be any harm in it, unless you get a cheap one and the magnet comes off and sticks to the crank. That could be interesting :lol: Some people also use a magnetic band around the oil filter housing. Quote Share this post Link to post Share on other sites
sankysvr6 0 Posted November 27, 2014 Cant see them doing any harm, unless they snap off inside the sump. Or you could get a neodymium magnet off ebay, and stick it on the head of the sump plug. Probably do the same the thing. Quote Share this post Link to post Share on other sites
sexybourbon 0 Posted November 27, 2014 Id avoid the sump plug and just get a very strong magnet and plop it on the outside of the sump to aboid any mishaps , it will still do the same job Quote Share this post Link to post Share on other sites
MarkFoster 0 Posted November 27, 2014 Id avoid the sump plug and just get a very strong magnet and plop it on the outside of the sump to aboid any mishaps , it will still do the same job Good suggestion. Anyone know where to source a suitably strong magnet? Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted November 27, 2014 Ebay use to sell loads Quote Share this post Link to post Share on other sites
sexybourbon 0 Posted November 27, 2014 Just bought two of these 161401411747 ebAy Quote Share this post Link to post Share on other sites
Dox 31 Posted November 27, 2014 Id avoid the sump plug and just get a very strong magnet and plop it on the outside of the sump to aboid any mishaps , it will still do the same job An external magnet fixed to the sump would collect any swarf, but you'd never be able to clean it off without removing the sump. An old speaker would provide a magnet if you went ahead with it Quote Share this post Link to post Share on other sites
sexybourbon 0 Posted November 27, 2014 Yoir right but i think even after a few years they wouldnt collect that much and then removing the sump to clear it wouldnt be to much of a job if you just scheduled it in to an oil change Quote Share this post Link to post Share on other sites
science 0 Posted November 27, 2014 (edited) The shape of the magnet is critical. Flat and wide disc N45 magnets will loose their magnetism, sometimes permanently, when heated to above 80*C, the long cylinder shape used in magnetic sump plugs is good for 140*C. N45 magnets are better the N52 in regards to operating temps. Edited November 27, 2014 by science Quote Share this post Link to post Share on other sites
Dox 31 Posted November 27, 2014 But the same swarf would be collected via the filter and disposed of several times before you remove the sump? Quote Share this post Link to post Share on other sites
dragon green 6 Posted November 27, 2014 I have one similar to this Goes between filter and housing,needs a longer bolt,but is easily split and cleaned out ! (I bought it from Demon Tweeks years ago,and on my "other car !) but it does work Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted November 27, 2014 When I took my oil pump off I found quite a few bits of metal in there. Mainly from the chain top tensioner blade. Also noticed something had got into the piston and been eaten by the engine. Had loads of dents in the piston. I reckon that might of been a bit of spark plug had fallen off though. Quote Share this post Link to post Share on other sites
stuarttaylor37 13 Posted November 27, 2014 Thanks for the replies you have an oil filer to do that job :) Its not doing its job then as I found a few small pieces of swarf when I dropped the sump last time. If the one referenced is as well made and as strong as the manufacturers claim could there be any detrimental effects? Quote Share this post Link to post Share on other sites
Dox 31 Posted November 28, 2014 Thanks for the replies Its not doing its job then as I found a few small pieces of swarf when I dropped the sump last time. The gauze in the oil pump pick up is doing its job then? Thanks for the replies If the one referenced is as well made and as strong as the manufacturers claim could there be any detrimental effects? Needless? dent in you wallet? Quote Share this post Link to post Share on other sites
stuarttaylor37 13 Posted November 28, 2014 The gauze in the oil pump pick up is doing its job then? Needless? dent in you wallet? Ok Roger Thanks for your advice :thumbleft: Quote Share this post Link to post Share on other sites
