Chuggs1
Replacememt roof aerial
Worth checking with vw so you can check it against the car. I bought new aerial off eBay and although it was almost perfect match Ulf only difference was the base was ever so slightly smaller and therefore a gasket would not have fitted otherwise the nut was exactly the same as was the connector for cable
Anyone have a picture of how the original gasket looks (when it's off, and maybe dimensions as well ?)
(I put in an order from the dealer for that gasket, but will be a while until I get it....)
Not sure if mine OLD aerial is OEM (i suspect not) :shrug:
At least give u an idea...
Linky here:
http://the-corrado.net/showthread.php?t=89983&page=126&p=1072344&highlight=Amplifier#post1072344
Some pics as well
(OLD aerial on right)
Thanks - here is a pic I got from the dealer (I guess he have it in his catalogue) - as it was some delivery time on this item:
From your pics it looks similar ?.....
Cheers
Cheers
Looks similar
Outer gasket
Inner seal (goes around bolt)
Nut (with the spikey other side to dig into ceiling when tightening)..
I can take pic of my OLD gasket later tonight if u want me to?
But bear in mind mine may not be OEM ...
Thanks appreciated! :)
Will have a look on the new one when I get it, and compare.....before doing the swap :)
