Wayne2015
Major Service: Where best for parts?
The benefit of getting from ECP/GSF is that its local and the brake parts you need are likely to be in stock. If they're not the right ones, you can return them for a full refund and get the ones you need. Your best bet is to look what you have on the car at the moment. I went for the larger pad thickness when I last bought a set, and had no issues.
Cheers Sean
U know me, even if i measure i still get the wrong parts!!!
Want to get it right
As will ordered thn taking with me to Vag-hag to fit together,
so just one shot at this :(
GSF serve the public?
As is Andrew Page?
I ll go to local Motor Factor and get some prices.
Then check with the suppliers Seanl82 gave me ;)
Then ECP
Then finally try TPS and then decide from the 4 quotes :)
Chris (Vag-hag)!
D-day -7 !!!
I need to ensure i get my car back by FRIDAY! EEEEK!
what time best me arriving?
Wotsapp me your address, bud!
And ensure your best lunch place / tea place is open too! ;) :)
All good bud,
Come for 09:00 as we have a good shot at it then. Hopefully the lift will be free, there was a blooming van on it today :( it doesn't matter really it's just much easier.
I'll get address to you no problem.
All good bud,
Cool bud!
I ll wear my best Sundays and get stuck in !!! :)
Er
Can't find PAS fluid (VW green stuff) at AV Sales :(
Is it genuine VW I need?
How many litres I need?
Also gearbox / transmission oil?
How much I need?
Any one got discounts with OPIE oils?
Thanks!
1 litre is enough and get it from vw
Gearbox oil you will need 2litres and alot of people go for redline mt90
Forum members get discount
Cool!
Will ring VW
Opie oils: do I just ring them and quote corrado.net?
The pas fluid from avs is febi stuff, but it's the correct specification Wayne, it's what I used in mine and the aqua I have. You can order online from Opie, just put the discount code in at checkout.
Thanks Sean!
I ll give VW a buzz too to see if thy cheaper :)
Er
What's the OPIE discount code (as a search here came back with out-of-date end-of-season codes in supplier section)?
Search for user oilman. I think the standard discount code is in his signature. Alternatively just give them a call, they're very helpful so will apply the discount over the phone anyway mate.
Damn
Might have left it too late
Many deliveries are specifying at least a week!!!!
Sean: AVS wants £13 delivered for Febi
- eBay also £13 - so may risk eBay ...
Redline MT90 sells at 1 US Quart = 0.9L
@£20
So will need £40 delivered..
Thanks Sean!
Found it!
Oilman (code: CORRADO) 10% off
Including delivery works out at £20 same as eBay!
But probably best to order from Oilman as safer :)
Sean!
APD wants £123 for standard NGK sparks (not £20)?!!!!
Are the cheaper NGKs from ECP ok?
Whats different between the £7 and £3 ones???
VW confirmed have a litre of PAS fluid for £10 :)
Though thy cannot confirm its GREEN :( :( :(
Shall i risk it?
Right!
Bought most stuff from ECP
1. PAGID front discs / pads (no ABS/wear ind)
2. PAGID rear discs / pads (ABS / no wear ind)
3. HT Leads (Pro Spark - any good)?
4. Rear Bearings (SK - any good)?
5. Sparks (NGK)
6. Drive belt (Contitech - any good)?
Right!
5. Sparks (NGK)
Re your number 4
If you mean SKF or snr they are fine and original fitment
Buy some rear carrier bolts you need 4 I gave you a link in the week to some off ebay or order from vw... You may have vag hag cursing if he has to use a set of irwins to get your out.
Edited by delfinis38
Buying everything stock
ECP say thicker rear pads will NOT fit !
As my car s PR number not match!
Only got pads
Rest ordered
Re your number 4
I think he just said SK (hopefully they are SKR)! Eeek!
I know still pricey at £27 (was it u who said £15)???
Carrier bolts???!!
ARGGGHHHHH!!!
Ok
Think got everything now
1. Everything from ECP, but
2. PAS fluid from VW (2moro)
3. Gear fluid from OPIE oil (just ordered)
Just need my car back now ...
