Tabbi 10 Posted March 12, 2015 Previous owner said he swapped it but still the same. I think i will try another for peace of mind. Quote Share this post Link to post Share on other sites
dragon green 6 Posted March 12, 2015 sankysvr6 said: Any chance you can flip that around so I can see how many contacts are on there. Still would like a picture of yours Tabbi to the colours of the wires going to it There are four types,early ones are different and only fit early's the ones shown fit the majority of Corrado's, what you have there Gentlemen is a 45 & 58mph unit Quote Share this post Link to post Share on other sites
sankysvr6 0 Posted March 12, 2015 (edited) Check the plug behind the fuse box W and V connections are next to each other. The V connector is for the MFA, so as thats not working as well might be simple as both plugs not pushed in fully. This is just hoping it's as simple as that. Edited March 12, 2015 by sankysvr6 Quote Share this post Link to post Share on other sites
Tabbi 10 Posted March 14, 2015 Will drop the fuse box in the morning and make sure everything's tight. Will also try pulling the clocks to make sure the wires behind there are all tight. Also will check wires around steering cowling. Gonna be busy but I want to get these issues sorted! Quote Share this post Link to post Share on other sites
Tabbi 10 Posted March 14, 2015 Ok so did all of the above, everything is plugged in tight. Boost pipe behind clocks is plugged in and good. My Control Module Part Number is: 535 919 845 A. What next... Swap module for working one? And if so can i borrow someones to test please..? Quote Share this post Link to post Share on other sites
mab 10 Posted March 16, 2015 hi is that your car on ebay for £4300 Quote Share this post Link to post Share on other sites
mab 10 Posted March 16, 2015 and am i correct to say you only paid £2000 for it of a fellow corrado member only 2 weeks ago Quote Share this post Link to post Share on other sites
Tabbi 10 Posted March 16, 2015 (edited) Hi, yes it is and that would be none of your business my friend. Out of curiousity, whats your point of bringing it up on my thread?? Edited March 16, 2015 by Tabbi Quote Share this post Link to post Share on other sites
mab 10 Posted March 16, 2015 hi my friend i just think its a bit cheeky asking for help just to make £2000 profit. Quote Share this post Link to post Share on other sites
Sean_Jaymo 0 Posted March 16, 2015 Free help, a couple of hours time and 2 grand profit. Nice. Quote Share this post Link to post Share on other sites
Chuggs1 10 Posted March 16, 2015 Surely there should be a forum donation! Would be nice gesture? Quote Share this post Link to post Share on other sites
delfinis38 1 Posted March 16, 2015 Chuggs1 said: Surely there should be a forum donation! Would be nice gesture? 2K donation..... :) Quote Share this post Link to post Share on other sites
Chuggs1 10 Posted March 16, 2015 Lol think that may be asking a bit much but who knows how far generosity goes?! Quote Share this post Link to post Share on other sites
Tabbi 10 Posted March 16, 2015 Lol Mab, is this the one that got away by any chance.... lol Quote Share this post Link to post Share on other sites
Tabbi 10 Posted March 16, 2015 Donation, no problem guys. It is the least i can do as i have been overwhelmed by the help and support of fellow members. Lets hope i can actually fix the issues i have been seeking advice on... :thumbleft: Quote Share this post Link to post Share on other sites
Tabbi 10 Posted March 16, 2015 So... now that we have got that off our chests.... what is going on with this Spoiler and MFA guys....? As you can appreciate fellas, If i am to make a 2k profit i need to fix these niggles right.....?? Haha Im messing.... lol Quote Share this post Link to post Share on other sites
Tabbi 10 Posted March 17, 2015 Ok, so i changed the control module earlier and still not working at the relevant speeds..... What next?? Quote Share this post Link to post Share on other sites
MZpog 10 Posted March 17, 2015 Tabbi said: Ok, so i changed the control module earlier and still not working at the relevant speeds..... What next?? Reduce the buy it now price to reflect the defect (sorry, couldn't help myself) Quote Share this post Link to post Share on other sites
Sean_Jaymo 0 Posted March 17, 2015 If it is working from the button and you are certain that it is getting a VSS feed, then the module needs replacing. Quote Share this post Link to post Share on other sites
sankysvr6 0 Posted March 17, 2015 When you checked the wiring, did you buzz it out with meter? Could be a break in the wire? Quote Share this post Link to post Share on other sites
Tabbi 10 Posted March 17, 2015 I think the broken wire is the culprit as speedo works fine so i assume that rules out VSS. Possible a wire from clocks to the module not sending readings?? Quote Share this post Link to post Share on other sites
Tabbi 10 Posted March 17, 2015 MZPOG, how about fix it and put price up....?? Lol Quote Share this post Link to post Share on other sites
Sean_Jaymo 0 Posted March 17, 2015 On the top of the fuse box there is a small distribution box with 3 or 4 white-blue wires plug into it. Those are your VSS feeds. Make sure that the module wiring is connected to this distribution box. As said before, buzz it out to make sure the wiring is continuous. Quote Share this post Link to post Share on other sites
Tabbi 10 Posted March 17, 2015 I did check them to make sure they were all plugged in and they were. Im quite handy with the mechanical side but haven't got a clue with the electrics. Wouldnt the car have to be driven whilst testing so that the signal can be sent?? Quote Share this post Link to post Share on other sites
Sean_Jaymo 0 Posted March 17, 2015 But if the wire is broken it doesn't matter what the car is doing. If the wire has continuity then the module is bust. Quote Share this post Link to post Share on other sites
