1xshaunx1 27 Posted May 25, 2019 I bought the plate cut and folded to shape 3mm aluminium from sheet metal works in Rotherham £45 then cut it with a jigsaw where needed. Hopefully I’ll see if it fits later fingers crossed it does. Quote Share this post Link to post Share on other sites
1xshaunx1 27 Posted May 26, 2019 (edited) I have built my fan unit tested it and fitted it, believe or not it actually went really well. Had to fettle the holes a bit for the after market rad but no dramas things went that fast and it was spitting I forgot to take more photos. Edited May 26, 2019 by 1xshaunx1 Quote Share this post Link to post Share on other sites
1xshaunx1 27 Posted May 26, 2019 I haven’t really got time at the moment Hasan to do anymore but if you or anyone else wants to get the plate made using the dimensions I used, happy to help, the photo is a quick sketch that I gave to the sheet metal works. Quote Share this post Link to post Share on other sites
swiftkid 1 Posted May 26, 2019 fla said: Looks very nice! for 2 x 11" fans? If the fit is ok, would you look to make any more? I'm sure there would be good demand for them. If needs be i can help with getting them made, if a drawing is available Hi, I've got a CAD drawing of a 9" and 11" fan bracket if its of any help, it's untested as I bought a set off ChrisL instead but happy to send my drawing through Quote Share this post Link to post Share on other sites
fla 9 Posted May 27, 2019 Not a bad idea. I can then get one if the guys in the office to modify it for 2 x 11" fans Is it something of interest to people? Quote Share this post Link to post Share on other sites
1xshaunx1 27 Posted May 27, 2019 I cut 2 off 280mm holes in it and 7mm holes to suit which ever fan used for fixings, used 6mm stainless bolts for fixings, you don’t need anything special as there is plenty of room between the rad core and the bottom of the new cowling. I didn’t bother wiring the third stage in, as if stage 2 can’t cope you are out of options. I did wire a switch in so I can manually bring them both in when I want. Quote Share this post Link to post Share on other sites
swiftkid 1 Posted May 28, 2019 You didn't wire as in left the wire loose? If I were you I'd definitely have that connected up. Stage 3 uses a different sensor so if you have problems on the rad fan sensor it's a failsafe plus if it gets hotter than stage 2 then instead of carrying on and still trying to cool it, it will cut the fan and you won't have any cooling whatsoever Quote Share this post Link to post Share on other sites
1xshaunx1 27 Posted May 28, 2019 I know what you are saying but if it carries on rising I need to stop. The manual switch I’ve wired in is battery fed so I can turn it on anytime even when the ignition is off both fans are on if I want, I did it like this to keep it fairly simple utilising as much of the loom as I thought safe. On the brief testing I’ve had since installed it’s doing what it should so I should be good. Most cars only have two stage these days so I should be good. Also if temps get too hot you get a warning on the dash if you aren’t paying attention to temps but I’m temp crazy as the turbo keeps you coming on your toes. Quote Share this post Link to post Share on other sites
swiftkid 1 Posted May 29, 2019 Yea I'm the same with temps, I'm constantly checking what's going as I've had loads of temp problems over the years. I know what you mean about having the switch available, just personal preference I suppose. My old rado had an override switch on the dash and a couple of times I forgot about it and only realised when it was worryingly hot. Quote Share this post Link to post Share on other sites
