pj027235 10 Posted March 28, 2016 Do you still have the mass airflow valve and/or the petrol tank straps? Cheers, Phil. Quote Share this post Link to post Share on other sites
Guest sam1990rhodes Posted April 24, 2016 Hi, is the front cross member is available? Quote Share this post Link to post Share on other sites
rado-steve 0 Posted June 13, 2016 sam1990rhodes said: do you have the fuse box cover/clips? also whats left from the 1.8t conversion? Mmm Bit late Replying :-/ Yes I have the clips & Cover! Got some G60 Driveshafts from the conversion, thats all really, and a MAP sensor I think. Quote Share this post Link to post Share on other sites
rado-steve 0 Posted June 13, 2016 G60_Chris said: Do you have both front windows? And what condition are they in? Any scratches etc? Thanks. Again, Apologies for late reply, not been on here for a while :( Yes I have them, drivers side has a scratch in it, passenger side is fine. Quote Share this post Link to post Share on other sites
rado-steve 0 Posted June 13, 2016 pj027235 said: Do you still have the mass airflow valve and/or the petrol tank straps? Cheers, Phil. Nope, sorry. Quote Share this post Link to post Share on other sites
rado-steve 0 Posted June 13, 2016 sam1990rhodes said: Hi, is the front cross member is available? Yes it is :) Thanks Quote Share this post Link to post Share on other sites
Hofmiester 10 Posted June 19, 2016 Do you have a 280mm brake calliper? Should be stamped with "54" thanks Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
rado-steve 0 Posted June 20, 2016 Hofmiester said: Do you have a 280mm brake calliper? Should be stamped with "54" thanks Sent from my iPhone using Tapatalk Hi, No mine had 256mm as it was a 16V, I upgraded these to 305mm Brembo's from an Ibiza Cupra R Quote Share this post Link to post Share on other sites
Bfstrachan 10 Posted June 21, 2016 Don't happen to have drivers headlamp for early spec? Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
rado-steve 0 Posted June 23, 2016 Bfstrachan said: Don't happen to have drivers headlamp for early spec? Sent from my iPhone using Tapatalk Both Sold mate, cheers Quote Share this post Link to post Share on other sites
dragon green 6 Posted July 6, 2016 Have you a fan controller,part no.1H0919506A Looks like this Quote Share this post Link to post Share on other sites
rado-steve 0 Posted July 18, 2016 dragon green said: Have you a fan controller,part no.1H0919506A Looks like this Thats from a 9A 16v (2.0) Mine was a 1.8 16V (KR) so they didn't have them. Sorry Quote Share this post Link to post Share on other sites
rado-steve 0 Posted July 18, 2016 Sorry to everyone who sent PM's, they are all now replied too. Had an "Off" on my motorbike & used a road sign as an airbag....it hurt somewhat :( Quote Share this post Link to post Share on other sites
mic_VR 3 Posted July 18, 2016 rado-steve said: Sorry to everyone who sent PM's, they are all now replied too. Had an "Off" on my motorbike & used a road sign as an airbag....it hurt somewhat :( Ouch! Hope you're OK mate. Quote Share this post Link to post Share on other sites
MZpog 10 Posted July 18, 2016 mic_VR said: Ouch! Hope you're OK mate. That's not what you ask a biker, you should ask "is the bike ok?" Seriously, hope your ok Steve. Quote Share this post Link to post Share on other sites
rado-steve 0 Posted July 18, 2016 mic_VR said: Ouch! Hope you're OK mate. Getting better fella Thanks, Slowly, but getting there MZpog said: That's not what you ask a biker, you should ask "is the bike ok?" Seriously, hope your ok Steve. Ha! It came off better than i did, sadly its all the plastics that have copped it....expensive :( Cheers Though Quote Share this post Link to post Share on other sites
Guest sam1990rhodes Posted August 3, 2016 hi mate, what did you do for the throttle cable? if it was an AGU do you still have it? Quote Share this post Link to post Share on other sites
rado-steve 0 Posted August 4, 2016 sam1990rhodes said: hi mate, what did you do for the throttle cable? if it was an AGU do you still have it? Mine was an AUQ so was DBW Quote Share this post Link to post Share on other sites
Stevenjohnson1984 10 Posted September 23, 2016 Hi there mate do you still have both headlights?? Cus I'll av them my number is 07467141491 Quote Share this post Link to post Share on other sites
kpl 10 Posted October 3, 2016 Hi, do you still have the heater blower? I only need the resistor Quote Share this post Link to post Share on other sites
MZpog 10 Posted October 3, 2016 kpl said: Hi, do you still have the heater blower? I only need the resistor If your resistor appears duff, it may be the thermal fuse which costs less than £1 to replace if your ok with soldering. Quote Share this post Link to post Share on other sites
rado-steve 0 Posted October 10, 2016 kpl said: Hi, do you still have the heater blower? I only need the resistor Hi, Yes still have the Blower Motor. Quote Share this post Link to post Share on other sites
rado-steve 0 Posted October 10, 2016 Stevenjohnson1984 said: Hi there mate do you still have both headlights?? Cus I'll av them my number is 07467141491 Nope, sorry Quote Share this post Link to post Share on other sites
