rabbit82 0 Posted April 22, 2015 Can you use a vr6 radiator as I'm struggling to find the g60 equivalent Cheers Jamie Quote Share this post Link to post Share on other sites
diarmaid16 1 Posted April 22, 2015 No, they are different sizes. G60 rad is availailable from vwheritage, just not in stock atm https://vwheritage.mobi/productDetails.cfm?iItemID=63346487 Quote Share this post Link to post Share on other sites
sankysvr6 0 Posted April 22, 2015 http://www.fastrads.co.uk/radiators/volkswagen/corrado/petrol/1.8+g60/index.html Quote Share this post Link to post Share on other sites
rickdonald 10 Posted April 23, 2015 http://www.fastrads.co.uk/radiators/volkswagen/corrado/petrol/1.8+g60/index.html Top company, I ordered one of the larger ones (742mm) for my G60, its a Hella unit and arrived the next day. Would definitely recommend. Quote Share this post Link to post Share on other sites
sparks 0 Posted April 24, 2015 No, they are different sizes. G60 rad is availailable from vwheritage, just not in stock atm https://vwheritage.mobi/productDetails.cfm?iItemID=63346487 so is it smaller or larger as ive a vr6 rad fitted to my G60 ?? cheers stu .. Quote Share this post Link to post Share on other sites
diarmaid16 1 Posted April 24, 2015 G60 is 430mm VR6 is 630mm Quote Share this post Link to post Share on other sites
rickdonald 10 Posted April 25, 2015 There was an option to fit a larger one as well though (742mm or something like that) for hot climate applications or "towing". I stuck one on instead to replace my knackered 430mm, as I didn't like how hot the coolant was getting in traffic. Mind you in all honesty it hasn't really helped much! Quote Share this post Link to post Share on other sites
sankysvr6 0 Posted April 25, 2015 (edited) I wouldn't have thought fitting a bigger radiator would have benefited anything, as it's the thermostat and rad fan switch. Which will govern how hot and cold things get. VW would have designed the radiator size to be most efficient for the size of the engine. Also the water pump, I would have thought would have some factor on efficiently things were cooling down The only benefit might be, if you couldn't find the standard radiator. Edited April 25, 2015 by sankysvr6 Quote Share this post Link to post Share on other sites
rickdonald 10 Posted April 25, 2015 The larger rad gives a bigger surface area so more chance for the heat to be transferred from the coolant to the surroundings. my thermostat was constantly open once the car had warmed up and in traffic the coolant climbed to above 110. The waterpump and fan are good as I checked them all, so thought the best thing (since I needed a new rad anyway) would be to spend a little more and get the larger one. It has abit, the temperatures are a lot more solid around 90, but after long enough in traffic it does start to climb up past 105 still. But it less of a worry than 110 or above. Quote Share this post Link to post Share on other sites
johnpmc22 1 Posted October 12, 2023 Any tips on where to pick up a excellent G60 radiator new/used these days? Quote Share this post Link to post Share on other sites
_Matt_ 32 Posted October 12, 2023 This is the part number to help your search 535121251B. I could only find an aluminium rad https://www.kuehler-rath.com/VW-Audi-Motorkuehler-12038-535-535121251B Quote Share this post Link to post Share on other sites
johnpmc22 1 Posted October 13, 2023 Thanks @_Matt_ strange web site thanks for sharing, would you have concerns over an aluminium rads? Quote Share this post Link to post Share on other sites
_Matt_ 32 Posted October 13, 2023 Yeah I know what you mean on the website but I have bought things from overseas via PayPal Goods and Services and not had a problem. If it does go south the Goods and Services will protect you. One thing to be mindful of is whether they will add on the VAT otherwise you'll be stung for that on import + import fees. Brexit has made things worse here for parts from Europe. Re alloy I probably would if I had no other option. For me it's about the athestics and I would just prefer some that looked OEM however if it's not possible to find an OEM my hand would be forced. In terms of alloy doing the job as well as an OEM I'd say it's just as good. Quote Share this post Link to post Share on other sites
johnpmc22 1 Posted October 13, 2023 Thanks @_Matt_ for all the advice ... i will shop around a little see if i can get an OEM Quote Share this post Link to post Share on other sites
EssexG60 1 Posted July 10, 2024 On 10/13/2023 at 3:27 PM, johnpmc22 said: Thanks @_Matt_ for all the advice ... i will shop around a little see if i can get an OEM Hi mate, any luck with OEM? I am in the same boat now. Seems Aluminium is the only way forward as no one seems to stock OEM. Quote Share this post Link to post Share on other sites
Wilko13 2 Posted July 20, 2024 Hi mate, any luck with OEM? I am in the same boat now. Seems Aluminium is the only way forward as no one seems to stock OEM. I have a mk2 golf gti rad in mine but to get it to fit you need to blank the charger off Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
