robrado974
Rattly windows problem
Morning chaps .
I had my rollers and window strips replaced a while back . everything was fine . Now they are worse then ever ! . It sounds like the glass is hitting on the mechanism that drives the windows up and down ?. Was there any padding of some sort that fitted to it ?. A friend who fits out campers did it for me , as i have mentioned on my members build thread , it was at a time where i had ,had the door cards off so many times with leaks and lock problems . It got on my nerves and i didnt want to do the job , especialy with the cost of the window strips ,i didnt want to fit them myself . The strips are obviously where they are meant to be . If you go over the warning raised strips on the road the windows sound like a drum roll !. Any help appreciated would be appreciated .
Kind regards .
Rob
Maybe the glass has come loose from the bonding that attaches it to the base that it sits in. Mine was pretty noisy before I fixed it.
