TanVr6
Tan's Blackberry VR
Speed sensor will always show up with the engine not running. If it's almost immediately cutting out it suggests immobiliser, though that should show up on VCDS as well. Is fuel pressure good?
Im pretty sure Leads are in the correct order.
Engine starts and runs, but just struggles to maintain smooth idling around 800rpm.
Then eventually cuts out.
Thinking the air flow meter is nakkered.
I also think it sounds like an immobiliser issue or leads in the wrong order. Out of interest, what ecu is yours? AG or perhaps CP?
Edited by fla
WooHoo!
It was the Air Flow Mass meter!
Sorted!!!
Bolts not coming out!!!
Good to hear it was a quick and easy fix. 👍
Bit of a bugger there on the rear axle, but at least there is good access and it won't throw your geometry out if it was a millimeter or two out. Moving along nicely. 😉
