seanl82 23 Posted September 9, 2020 Speed sensor will always show up with the engine not running. If it's almost immediately cutting out it suggests immobiliser, though that should show up on VCDS as well. Is fuel pressure good? Quote Share this post Link to post Share on other sites
TanVr6 0 Posted September 9, 2020 Im pretty sure Leads are in the correct order.Engine starts and runs, but just struggles to maintain smooth idling around 800rpm.Then eventually cuts out. Thinking the air flow meter is nakkered.Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
1xshaunx1 27 Posted September 10, 2020 When it’s cold it doesn’t take a signal from the maf. Quote Share this post Link to post Share on other sites
fla 9 Posted September 10, 2020 (edited) I also think it sounds like an immobiliser issue or leads in the wrong order. Out of interest, what ecu is yours? AG or perhaps CP? Edited September 10, 2020 by fla Quote Share this post Link to post Share on other sites
TanVr6 0 Posted September 12, 2020 WooHoo!It was the Air Flow Mass meter!Sorted!!!Next problem... Bolts not coming out!!!Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
TanVr6 0 Posted September 12, 2020 Done...Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
seanl82 23 Posted September 12, 2020 Good to hear it was a quick and easy fix. 👍 Bit of a bugger there on the rear axle, but at least there is good access and it won't throw your geometry out if it was a millimeter or two out. Moving along nicely. 😉 Quote Share this post Link to post Share on other sites
