Goldie 2 Posted July 19, 2015 (edited) Im going to start a thread on this car to keep a track of the progress on the jobs I'm doing. The car is for sale but i can't update the advert so this seem the best way. I bought the car along with an 8v and mountain of parts last year. Anyway, the car its a 1994 VR6 with 62k on the clock. It has factory Recaro Leather and Headlight washers. It has also been fitted at the dealers with Diavia Aircon and a Zender bodykit. It has been dry stored most of its life hence the low mileage. In the last few years the suspension has been refurbished so rear beam powder coated with new bushes and bearings. Upfront the subframe and wishbones have has the same treatment. Ill post some mored details later on but here are a couple of pictures of it as it stands. Edited July 19, 2015 by Goldie Quote Share this post Link to post Share on other sites
Goldie 2 Posted July 19, 2015 List of jobs that need doing: Oil leak from oil filter housing. Oil temperature does not read on MFA. Bonnet foam rotten. Door card top trims cracked. Mirrors do not move on the switch. Heater direction control temperamental. Ignition switch intermittent. I made a start on these over the weekend. The low pressure oil switch was passing oil up through the spade. This has been replaced with a new one. Oil temperature switch changed for a new one. Bonnet foam removed and one from the group buy fitted. Bonnet foam originally. Half way through the job. And finished. If the weather holds ill try and do a bit more on the car today.. Quote Share this post Link to post Share on other sites
delfinis38 1 Posted July 19, 2015 Looks tidy. Hummm ignition switch i had fun with one of those yesterday... I've got one or two bent screwdrivers now. I want your recaros :) Quote Share this post Link to post Share on other sites
Goldie 2 Posted July 19, 2015 Ive heard a lot of stories about changing the ignition switch, not looking forward to it but I'm sure ill get there.. The passenger seat wiring needs sorting out but overall these are the best OE Recaros I've seen. Zero bolster wear or marks on the leather. They may end up coming out the car.. Quote Share this post Link to post Share on other sites
delfinis38 1 Posted July 19, 2015 (edited) Ive heard a lot of stories about changing the ignition switch, not looking forward to it but I'm sure ill get there.. The passenger seat wiring needs sorting out but overall these are the best OE Recaros I've seen. Zero bolster wear or marks on the leather. They may end up coming out the car.. That's why I'm interested in the Recaros they must be similar condition to my interior. Ignition switch not too bad, theirs a bit in wiki on it. I left the seat in, lowered the steering wheel and removed the steering wheel plastic. The problem is getting at the screw. The screwdriver needs to go round a corner. So you need to bend a screwdriver. Just needs a bit of patience. I bought a genuine switch from the dealer for £35. But I intend to keep the car and do the job once... Guess if your selling you could save a few quid. Flash red suits the car. Edited July 19, 2015 by delfinis38 Quote Share this post Link to post Share on other sites
easypops 8 Posted July 19, 2015 Looks great mate, nice job on the bonnet foam, the ignition switch isn't too bad, fairly sure I ended up getting to the screw from above after trying from below, getting it back in was the worst bit. Let's see some pics of these seats then 8) Quote Share this post Link to post Share on other sites
delfinis38 1 Posted July 19, 2015 Looks great mate, nice job on the bonnet foam, the ignition switch isn't too bad, fairly sure I ended up getting to the screw from above after trying from below, getting it back in was the worst bit. Let's see some pics of these seats then 8) Yup from above, perched on the seat. Non of this upside down rubbish as mentioned in the wiki. Quote Share this post Link to post Share on other sites
Goldie 2 Posted July 19, 2015 Door card top trims changed... Seats: Quote Share this post Link to post Share on other sites
Jim 2 Posted July 19, 2015 I ended up doing the ignition switch from underneath having taken the front seat out - not sure if it's a bit more involved removing recaro's though than the standard seats! As others have said, a long thin screwdriver with an appropriate little bend in it and it was not too bad a job then. I cable tied in the replacement though I have to say - there was no way that little screw was going back without a fight! Quote Share this post Link to post Share on other sites
easypops 8 Posted July 19, 2015 The seats do look spot on, very nice indeed 8) Quote Share this post Link to post Share on other sites
seanl82 23 Posted July 19, 2015 Seeing as there is a lot of mention of ignition switches, I'll give my 2 pence too! I've done two of them. One on my old valver which I had an utter nightmare with, and cable tied in as others have done. The switch I replaced on the current car was actually really easy. Didn't need to bend a screwdriver or anything like that, it went in an absolute doddle. Didn't cure the intermittent (non)cranking issue I still have (probably starter motor), but the key turn feels much more solid now so it was obviously well past its best. Both times I did it from below with seat removed. Shame I can't see the photos, but I'll have a look when I'm back in the UK for a couple of weeks, in 6 weeks time. :thumbright: Quote Share this post Link to post Share on other sites
robrado974 1 Posted July 19, 2015 Looks a very nice car Goldie . I love the colour and the seats are very nice . Low mileage too . RE the ignition switch , Im ashamed to say I gave up . And had to hammer the screw out and cable tie the new one in . A friend did his on a T4 with no problems , could we do mine ? Er no , I did the same on my T4 as well . Quote Share this post Link to post Share on other sites
Goldie 2 Posted August 8, 2015 Update... 12 Months MOT today, no advisories. Tester commented on how well overhauled the car was and the emissions are super low...Its covered a huge 150 miles this year.. Quote Share this post Link to post Share on other sites
easypops 8 Posted August 9, 2015 No surprise there mate, it's gonna be a cracking buy for someone 8) Quote Share this post Link to post Share on other sites
Hairyarse 10 Posted August 10, 2015 That's a beauty! Quote Share this post Link to post Share on other sites
Goldie 2 Posted August 13, 2015 Car is now sold and will be collected by its new owner on Friday.. Quote Share this post Link to post Share on other sites
diarmaid16 1 Posted August 13, 2015 Nice one. Great looking example. Hope it's going to a good home! Quote Share this post Link to post Share on other sites
g0ldf1ng3r 17 Posted August 13, 2015 great news goldie is the new owner on the forum currently do you know? Quote Share this post Link to post Share on other sites
Goldie 2 Posted August 13, 2015 It has gone to a very good home. Forum member yes but not a well known one. Ill leave it up to the new owner whether they wish to spill the beans... Quote Share this post Link to post Share on other sites
g0ldf1ng3r 17 Posted August 13, 2015 It has gone to a very good home. Forum member yes but not a well known one. Ill leave it up to the new owner whether they wish to spill the beans... cool, good news m8 lets hope we see it here soon maybe Quote Share this post Link to post Share on other sites
