karmannski 0 Posted August 16, 2015 Mileage 105K VR6 Corrado. Starts at 2k + revs. All shields are ok, my mechanic is not 100% sure what it is, perhaps lifters. So I added special fluid to clean them, yeasterday but only done 5miles since. Maybe it will stop after whille. any ideas? Quote Share this post Link to post Share on other sites
Jim 2 Posted August 16, 2015 Hmmm... have you had the timing chain & tensioners inspected? Might be worth also getting a stethoscope to see if you can work out from where abouts the noise is coming from. I suspect it's probably some kind of valve train noise, and most likely lifters. Had an extremely stuck / noisy one on mine recently and tried some tappet additive from Halfords which, after about 60-70 miles seemed to improve things, but after a 200 mile round trip this weekend the noise has returned so. Your mileage may vary. Best to budget for a new set of INA tappets (which can be found for about £85). Quote Share this post Link to post Share on other sites
dr_mat 0 Posted August 17, 2015 Personally I think the noisiest bit on most aging VR6s is the oil filter drive gear-train. Really upset that we didn't think to swap the middle shaft when the timing chains were done. Quote Share this post Link to post Share on other sites
fendervg 32 Posted August 17, 2015 Will also be noisier when you have a metal rocker cover versus the plastic one. Quote Share this post Link to post Share on other sites
g60knight 0 Posted September 1, 2015 did u find out what it was? Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted September 1, 2015 Sound chainy to me, maybe chain passing over a worn top tensioner, as Jim says, get a cheap stethoscope, i found it amazing to pin point a noise Quote Share this post Link to post Share on other sites
g0ldf1ng3r 15 Posted September 1, 2015 ouch! sounds a tad concerning :( Quote Share this post Link to post Share on other sites
karmannski 0 Posted September 1, 2015 Not yet, I need to get stethoscope 1st. I will have, more questions anyway. Quote Share this post Link to post Share on other sites
karmannski 0 Posted October 3, 2015 problem solved. Faulty lifters, got new lifters in sond sweet Quote Share this post Link to post Share on other sites
