Purple Tom 0 Posted September 28, 2015 Hi Jon, Yep, still got the gearbox. All in full working order. I'd like £100 collected for it. Cheers Tom Quote Share this post Link to post Share on other sites
Cressa 45 Posted October 4, 2015 Do you still have the sunroof motor available? Quote Share this post Link to post Share on other sites
Purple Tom 0 Posted October 4, 2015 Hi Cressa, I do indeed yes. As far as I'm aware its fully functional, tested and working although not on the sunroof directly as the mechanism was broken. £30 posted. Cheers Tom Quote Share this post Link to post Share on other sites
andyhudson 10 Posted October 7, 2015 (edited) im after standard set of shocks and spring, you got these? and price posted please, unless you venture up near burnley/manchester way alot also after an outer window seal that goes our the drivers window on the outside. if you have the cover for the rear wiper jet that would be good as well. also i need of late headlight glass on one side and fog and indicators un cracked. i cant remember off hand which sides they are but can check if you know you have some Edited October 7, 2015 by andyhudson Quote Share this post Link to post Share on other sites
Purple Tom 0 Posted October 7, 2015 (edited) I'm afraid the springs are sold but I do have the shocks. The rears are relatively new and the fronts are probably original but all appear good with no fluid leaks. I have the outer door rubber and I've got the rear wiper cover. Prices as follows: Shocks - £30 for the 4 (£7.50 each) Door rubber and washer jet cover - £20 Postage - £10 £60 in total :-) Thanks Tom Edited October 7, 2015 by Purple Tom Quote Share this post Link to post Share on other sites
Dan7690 10 Posted October 8, 2015 Have you still got the rear number plate plinth? Also I need the drivers side lower window rubber?? Thanks Quote Share this post Link to post Share on other sites
Purple Tom 0 Posted October 9, 2015 The number plate plinth is unfortunately damaged. Do you mean the window scraper that runs horizontally along the door at the bottom of the window? Quote Share this post Link to post Share on other sites
Dan7690 10 Posted October 9, 2015 How damaged is it? Fixable or not? Yeah that's the window scraper I need? How much? Quote Share this post Link to post Share on other sites
Purple Tom 0 Posted October 10, 2015 There's a crack on the bottom right corner, it'd be possible to repair but it might still be visible if you looked closely. If you wanted the pair I'd do them both for £40 including postage. Thanks Tom Quote Share this post Link to post Share on other sites
paxman 0 Posted October 14, 2015 Hi Is the brake reservoir cap and plugs / wiring above still available for £15 posted? If so I'll take them. Paypal? Pm? Jim Quote Share this post Link to post Share on other sites
agron43 10 Posted October 16, 2015 Hello mate do you have this hose Quote Share this post Link to post Share on other sites
llukejp 10 Posted October 17, 2015 Hey bud I now you prob have already said in the thread somewhere but we're are u based and do you still have the sub frame set up. I.e subframe, lower arms, hubs, steering rack pretty much the hole front end. Cheers luke Quote Share this post Link to post Share on other sites
Purple Tom 0 Posted October 17, 2015 Jim - Brake reservoir cap sold I'm afraid! Agron43 - Yeah I've got a couple of those hoses - £15 posted. Luke - I'm afraid the front end set-up has sold. The only item I have left is the steering rack. Sorry dude. Tom Quote Share this post Link to post Share on other sites
agron43 10 Posted October 17, 2015 Thanks Tom can I pay with Peypal Quote Share this post Link to post Share on other sites
corrado666 10 Posted October 19, 2015 Sent pm Quote Share this post Link to post Share on other sites
Craig Parker 10 Posted November 4, 2015 Do you have the accelerator cable to the vr6? I need one with the triangle hook end. If so can you show a pick please. Quote Share this post Link to post Share on other sites
Purple Tom 0 Posted November 4, 2015 I'm not sure what you mean by the triangular hook end. I have two cables, both like this: If that's what you need then let me know. £15 posted. Cheers Tom Quote Share this post Link to post Share on other sites
Craig Parker 10 Posted November 4, 2015 Yea, thanks. Not the one I need. Quote Share this post Link to post Share on other sites
Craig Parker 10 Posted November 4, 2015 Thanks for your help mate. Quote Share this post Link to post Share on other sites
kevwil1968 1 Posted November 4, 2015 Tom, Dave suggested I contact you about finding a sunrof mechanism, do you have one in working order ? Quote Share this post Link to post Share on other sites
Purple Tom 0 Posted November 4, 2015 Unfortunately not, the nearside sliding components on the mech that I've got are damaged - sorry!! Quote Share this post Link to post Share on other sites
kevwil1968 1 Posted November 4, 2015 ok thx anyway Tom.. just have to keep trying.. Quote Share this post Link to post Share on other sites
ozone 10 Posted November 10, 2015 Hi Tom I seem to have the dreaded dashboard abs light permanently on. Do you think still have the abs pump and module? Quote Share this post Link to post Share on other sites
ozone 10 Posted November 10, 2015 Also, and more importantly i guess, would it fit an automatic vr6? Quote Share this post Link to post Share on other sites
Purple Tom 0 Posted November 11, 2015 Hi, unfortunately I don't have the pump, although I still have a couple of spare ECU's. Have you plugged it into Vagcom to see what faults it has? Quote Share this post Link to post Share on other sites
