robrado974 1 Posted October 26, 2015 Ok . The main part that sits under the engine is the subframe correct ? . The crossmember is also the rad support? . Just so I know to ask for the right parts . When I google the pics of these , they both come up as one heading . Thanks Rob Quote Share this post Link to post Share on other sites
GlosterOx 0 Posted October 26, 2015 Not sure if this helps or not Rob? http://www.vagcat.com/epc/cat/vw/COR/1994/76/49/842822/ No:16 is referred to as the subframe. Ian. Quote Share this post Link to post Share on other sites
robrado974 1 Posted October 26, 2015 Thanks Ian . I will have to register with them as it won't show me the images . Regards Rob Quote Share this post Link to post Share on other sites
easypops 8 Posted October 26, 2015 I'm on my phone so can't see the above link. There are 3 separate items. Subframe, crossmember and radiator support. I can stick a few pictures up later this evening if it will help? :) Quote Share this post Link to post Share on other sites
robrado974 1 Posted October 26, 2015 That would be great Easypops . Thank you . Quote Share this post Link to post Share on other sites
GlosterOx 0 Posted October 26, 2015 Thanks Ian . I will have to register with them as it won't show me the images . Regards Rob Opps, sorry - Forgot I was already logged in! Ian. Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted October 26, 2015 Top is the front cross member, (sometimes i've seen this called a subframe), Bottom is the rad support (which i've seen called a crossmember) And then the subframe Quote Share this post Link to post Share on other sites
robrado974 1 Posted October 26, 2015 Great thanks for that . As usual this forum is worth its weight in gold . Thanks again chaps . Quote Share this post Link to post Share on other sites
Philly-R6 0 Posted October 26, 2015 Jim Ellis VW Parts exposes the parts catalog, if you don't want to register: http://www.jimellisvwparts.com/showAssembly.aspx?ukey_assembly=739482&ukey_make=1066&ukey_model=15552 Hey Jim, What is the knack to insert the four rubber mountings into the engine carrier/front subframe/cross member? Quote Share this post Link to post Share on other sites
robrado974 1 Posted October 26, 2015 Great , thank you . Quote Share this post Link to post Share on other sites
ChrisL 20 Posted October 26, 2015 Jim Ellis VW Parts exposes the parts catalog, if you don't want to register: http://www.jimellisvwparts.com/showAssembly.aspx?ukey_assembly=739482&ukey_make=1066&ukey_model=15552 Hey Jim, What is the knack to insert the four rubber mountings into the engine carrier/front subframe/cross member? Lots of fairy liquid, a piece of tube and a threaded rod to pull them in. Quote Share this post Link to post Share on other sites
