robrado974 1 Posted November 9, 2015 As title chaps . Ive removed my carpets and deadening as its had it . Ive bought the delux underlay for the footwells front and rear . But ive noticed the bits that fit next to the hump and under the pedals and round the back under the heater motor ect have also had it ,they have soaked up the water from a leak . . I ve looked at Heritage and there are a few types , but none are like the original set . Has anybody made their own ? or used something else . Some of the items are not cheap either . Any advice would be great . Rob Quote Share this post Link to post Share on other sites
Jim 2 Posted November 9, 2015 Dynamat is very well regarded stuff I believe. Quote Share this post Link to post Share on other sites
Dox 23 Posted November 9, 2015 T4 / T5 van owners use this stuff http://www.ebay.co.uk/itm/151155678947?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT Quote Share this post Link to post Share on other sites
robrado974 1 Posted November 10, 2015 Thanks Jim and Dox . I believe the oem stuff is no longer available . So I will have to find something to bulk up the gap . The new stuff is just a pad , so I suppose you fit this and glue some decent underlay to it ? . Other wise the carpet will have a void and not fit correctly . Quote Share this post Link to post Share on other sites
Dox 23 Posted November 10, 2015 http://www.ebay.co.uk/itm/Silent-Coat-Isolator-2-Large-Sheets-10mm-Insulation-Foam-Car-Van-Sound-Proofing-/161242282433?hash=item258ac9f9c1:g:2x4AAOSwPhdVMQl7 Quote Share this post Link to post Share on other sites
robrado974 1 Posted November 10, 2015 Nice one Dox . Thank you , that's more like the thickness I need . Quote Share this post Link to post Share on other sites
fla 9 Posted November 10, 2015 What you need is some closed cell foam to decouple the noise source and then some open cell foam to absorb any airborne noise. Then a barrier to block any noise transmission. I would keep the black heavy sheets but just remove all the old manky foam. Use this on top of any insulation you use. Its also useful for tracing the correct profile of insulation. Quote Share this post Link to post Share on other sites
