sexybourbon 0 Posted January 19, 2016 As Above please , wich obd2 scanners are you using ? Iv had a look on ebay but there is so many i font know wich one to pick !! There is one from elm wich looks ok but there are several Iv got a few lights on id like to clear of the daily volvo , one is the check engine light and im off to look at a breaker and would like to see if i can reset the srs airbag light to see what is wrong with it I font want to spend over 15 to 20 quid and its got to work with iphone and ideally the torque app Any info would be great and i already know they arent perfect or snap on but id like one anyway Cheers Quote Share this post Link to post Share on other sites
swiftkid 1 Posted January 20, 2016 I've got an elm Bluetooth one you can try if you want? It's OK, not amazing. I use it with the torque app and can reset codes Quote Share this post Link to post Share on other sites
sexybourbon 0 Posted January 20, 2016 Do you have a link mate to the exact one ? Im going to buy one anyway mate for the future but i want a blue tooth one as there mostly wifi now and i dont have a wifi dongle Thanks for the offer though if i do get stuck ill give you a shout A model number and what not would be exellent bud Quote Share this post Link to post Share on other sites
VW_OwneR_85 2 Posted January 20, 2016 I brought this for my mk4 golf , works a treat! and cheap http://www.ebay.co.uk/itm/Konnwei-KW809-Car-Diagnostic-Scanner-CAN-OBD2-Code-Reader-Tool-VW-Audi-VS-VAG405-/221638141140?hash=item339aa9a4d4:g:GZwAAOSwBLlVAQsp Quote Share this post Link to post Share on other sites
swiftkid 1 Posted January 20, 2016 Erm the elm327 I think, bought it absolutely ages ago. Was only cheap so took a risk, works on the rado if you convert to obd2 as well ;) Not sure what you mean about WiFi scanner though, never seen a WiFi obd scanner before Edit: think it's same as this http://pages.ebay.com/link/?nav=item.view&id=221938206427&alt=web Quote Share this post Link to post Share on other sites
VR-OOM 0 Posted January 20, 2016 I've just bought a Vgate VS450 scanner for my 54 Passat, works a treat and it works with OBD2 Quote Share this post Link to post Share on other sites
eugopnosaj 0 Posted January 21, 2016 Just a word of advice, double check which one works with your car. I've got an ELM 327 which only works on the various fords I've worked on, it doesn't work on the Corrado (which is only OBD1 anyway so wouldn't regardless) nor my legacy engined beetle, the VW 409.1 cable however works on the Corrado and the Subaru ECU. I bought a cheap ELM bluetooth one and although it connects to my phone and can be seen over bluetooth it doesn't communicate, that's both using Torque and Dashboard etc. Quote Share this post Link to post Share on other sites
sexybourbon 0 Posted January 22, 2016 Cheers all , i think the new ones are wifi enabled dave not bluetooth ! Wich i wouldnt want Cheers for your suggestions im gonna order one today Quote Share this post Link to post Share on other sites
Yandards 0 Posted January 22, 2016 The VAG COM canbus one works fine with pretty much everything.. Quote Share this post Link to post Share on other sites
