black dub 0 Posted March 2, 2016 (edited) Zeitronix zt-2 wideband afr meter + data logging system with blue display 52mm gauge unused nib retails at £310. The kit contains: The Zt-2 Wideband AFR Controller, Wideband Oxygen Sensor, O2 Harness, Signal Harness, Datalogging Software, Installation Instructions, 2 pin EGT connector. http://www.efi-parts.co.uk/index.php?productID=172 Plus I also have the EGT probe + extension cable retails at £70 http://www.efi-parts.co.uk/index.php?productID=174 Plus genuine 3.5bar boost sensor retails at £95 http://www.efi-parts.co.uk/index.php?productID=185 This complete zeitronix kit totals £475 do it for £320. Edited April 27, 2016 by black dub Sold 1 more item Quote Share this post Link to post Share on other sites
Jim 2 Posted March 2, 2016 Have you got a price in mind for the OBD2 setup with the bog standard manifold? I've no idea on value either, but my engine is just about to come out of the car so would be an ideal time to swap to OBD2. Is the loom ready to install or does work need to be done on it? Quote Share this post Link to post Share on other sites
g0ldf1ng3r 17 Posted March 2, 2016 Have you got a price in mind for the OBD2 setup with the bog standard manifold? I've no idea on value either, but my engine is just about to come out of the car so would be an ideal time to swap to OBD2. Is the loom ready to install or does work need to be done on it? oooo that sounds interesting Jim!!!! :D Quote Share this post Link to post Share on other sites
black dub 0 Posted March 2, 2016 Hi Jim the loom is good to go but will need re wrapping in loom/cloth tape as I was going to hide it all as car is having a shaved bay, only reason I'm selling is because I'm going standalone management. I'll take some pics when at my workshop later for u to see Quote Share this post Link to post Share on other sites
Jim 2 Posted March 2, 2016 I'm tentatively interested subject to a price, and a discussion with the garage as to whether they're willing to go through installing it or not :) Quote Share this post Link to post Share on other sites
black dub 0 Posted March 2, 2016 It's really easy to install yourself bud, I've even labeled up all the plugs for location to make it so simple. Plus as I take it its going in a corrado both ur light and fan loom r separate so only engine loom n engine harness to swap for obd2 Quote Share this post Link to post Share on other sites
Jim 2 Posted March 2, 2016 So how much? I don't want to lowball you but honestly have no idea of value. £150? Quote Share this post Link to post Share on other sites
Dox 31 Posted March 2, 2016 I'll also express an interest in the OBD2 stuff, but Jim was first. Has the loom been used by you or just readied to fit? The ODB2 head, what's involved in fitting this to an ABV block? In the past I've seen another here with chemical metal used to block something off? Quote Share this post Link to post Share on other sites
black dub 0 Posted March 2, 2016 Ok I've had a little look about to see what the obd2 is worth n if u say the inlet £60-80 and throttle body go for about £60 then factor in £75 to have the ecu immobiliser removed plus maf sensor n coilpack then the time I've spent stripping back all the crap that is not used as mk3 golf light n fan loom is all integrated. So I would say £300 and I could probably include delivery in that too. Yes I have had my corrado running on this obd2 loom then removed it all as was going to lengthen and shorten areas of the loom as having a shaved bay but have decided to run standalone management for better control of boost and turning. Quote Share this post Link to post Share on other sites
Jim 2 Posted March 2, 2016 Cheers for a price but a bit more than I want to spend I think so will let you have second dibs, Dox. Quote Share this post Link to post Share on other sites
black dub 0 Posted March 2, 2016 I'll also express an interest in the OBD2 stuff, but Jim was first. Has the loom been used by you or just readied to fit? The ODB2 head, what's involved in fitting this to an ABV block? In the past I've seen another here with chemical metal used to block something off? The obd2 head is bolt for bolt swap but has larger Oil ways and this obviously has larger valves n ported out all by schrick n I think I still have the receipt somewhere that can supply. I'm open to offers on all items. Quote Share this post Link to post Share on other sites
20vtvw 0 Posted March 2, 2016 I'm interested in the pro maf,do you have any pics ? Cheers Quote Share this post Link to post Share on other sites
black dub 0 Posted March 2, 2016 Hi I've tried lots of times to upload pics. If u have Facebook I'll put up link https://m.facebook.com/groups/1520173351581315?view=permalink&id=1650519581880024 Quote Share this post Link to post Share on other sites
Dox 31 Posted March 3, 2016 Hi I've tried lots of times to upload pics. If u have Facebook I'll put up link https://m.facebook.com/groups/1520173351581315?view=permalink&id=1650519581880024 That link doesn't work for me, is it a closed group? I have seen the loom on FB VW Golf/Corrado/Caddy - Cars and Parts Forsale + Wanted. But I can find any of the head. Quote Share this post Link to post Share on other sites
black dub 0 Posted March 3, 2016 I will get some pics of head today. Quote Share this post Link to post Share on other sites
alex303 0 Posted March 3, 2016 If the Schrick BV head is the 'double chain' type (double sprockets on the cams) i.e. 93-95 or early 96 ODB2 and is as described then i'll take it at the stated price £500. I'm in Kent so could collect / pay this weekend, I would need a copy of that receipt from Stealth to add to my paperwork though. After alot of thought of which direction to take my corrado I have decided to sell the following: Schrick big valve head (obd2) this was on my supercharged engine it has 2mm oversized inlet and outlet valves and flowed out, this was supplied by stealth racing which I have recieps totalling around £2000 this is in excellent condition and could just do with face cleaning and valves re lapped back in. This has got to be worth £500. Quote Share this post Link to post Share on other sites
black dub 0 Posted March 5, 2016 Big valve head SOLD to alex303 Quote Share this post Link to post Share on other sites
Dox 31 Posted March 5, 2016 Offer £200 for the OBD2 stuff Quote Share this post Link to post Share on other sites
black dub 0 Posted March 6, 2016 Offer £200 for the OBD2 stuff Is ur car coilpack or dizzy Quote Share this post Link to post Share on other sites
MDMTechnik 10 Posted March 6, 2016 Definitely sold BV head? Quote Share this post Link to post Share on other sites
black dub 0 Posted March 6, 2016 Yes head went this morning Quote Share this post Link to post Share on other sites
Dox 31 Posted March 6, 2016 Is ur car coilpack or dizzy Coilpack Quote Share this post Link to post Share on other sites
black dub 0 Posted March 6, 2016 I could prob drop to £250 at best if u collect or I can find out postage cost for u. Quote Share this post Link to post Share on other sites
Dox 31 Posted March 6, 2016 I could prob drop to £250 at best if u collect or I can find out postage cost for u. Can I use my existing coilpack then? What map is in the ecu, standard? Quote Share this post Link to post Share on other sites
black dub 0 Posted March 6, 2016 Yep u can use existing coilpack, ecu is standard it's just had the immobiliser removed so can keep original key and no extra wiring Quote Share this post Link to post Share on other sites
