robrado974 1 Posted March 9, 2016 Evening chaps, Does anyone know if it's possible to remove paint from my door handles ? . They were painted when the car was resprayed . Six years on and I want to go back to black oem. I only ask as looking at the prices on flea bay , they ain't cheap . Thanks Rob Quote Share this post Link to post Share on other sites
seanl82 23 Posted March 9, 2016 I think a bit of thinners on a sponge would get it back eventually Rob. You could try to rub it down a little bit first, but just be careful you don't damage the slightly textured plastic. Quote Share this post Link to post Share on other sites
robrado974 1 Posted March 9, 2016 Thanks Sean . I may well give it s go . I'm a little concerned it could turn out messy though and I end up with nasty looking handles . Looking at the bay , you wouldn't have thought handles would be that expensive, not exactly a rare item . Quote Share this post Link to post Share on other sites
seanl82 23 Posted March 9, 2016 If you do find a reasonable price set mate, just bare in mind they differ slightly from early/late cars if you didn't know. The early ones have a lip around the lock barrel where as the later ones are more flush. Quote Share this post Link to post Share on other sites
robrado974 1 Posted March 9, 2016 Yep , your right mate , they do differ . If I get no joy in removing the paint I will be keeping a look out . Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted March 9, 2016 seanl82 said: If you do find a reasonable price set mate, just bare in mind they differ slightly from early/late cars if you didn't know. The early ones have a lip around the lock barrel where as the later ones are more flush. They do differ but I'm sure it's other way round chaps Quote Share this post Link to post Share on other sites
seanl82 23 Posted March 9, 2016 VAG-hag said: They do differ but I'm sure it's other way round chaps Think you're right Chris, just couldn't be arsed to go outside in the cold and wet to be sure! lol Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted March 9, 2016 Could you rub them down a little and then paint them a satin or matt black. No need to worry about them fading then. I thought of doing mine and the rubstrips as all the back to black type products I've used never last very long. Quote Share this post Link to post Share on other sites
VW_OwneR_85 2 Posted March 9, 2016 you could try making a bath of cheap brake fluid and leave the handles to soak for a day or two, Quote Share this post Link to post Share on other sites
SR_Neale 10 Posted March 10, 2016 You can buy textured paint for any decent paint supply shop and fleabay. I would flat them down with 800 wet and dry then use the texture paint after a coat of plastic adhesions promoter. I wouldn't use any type of thinners or brake fluid as it will damage the plastic. I also have some early one in good condition if all else fails. Quote Share this post Link to post Share on other sites
SR_Neale 10 Posted March 10, 2016 http://m.ebay.co.uk/itm/PLASTIC-BUMPER-DASH-BODY-AEROSOL-TEXTURED-TEXTURE-PAINT-/370334037195?nav=SEARCH Quote Share this post Link to post Share on other sites
SR_Neale 10 Posted March 10, 2016 http://m.ebay.co.uk/itm/U-POL-PLASTX-2-ADHESION-PROMOTER-400ml-PLASTIC-REPAIR-upol-BEST-price-/221465284972?nav=SEARCH Quote Share this post Link to post Share on other sites
SR_Neale 10 Posted March 10, 2016 When using the textured paint the more coats you put on the thicker it will get. Quote Share this post Link to post Share on other sites
robrado974 1 Posted March 10, 2016 Thanks for the replies, I will look into this soon . Many thanks Rob Quote Share this post Link to post Share on other sites
'Rado_TDI 10 Posted March 10, 2016 lol I just painted mine - could have done a swap :bonk: Quote Share this post Link to post Share on other sites
robrado974 1 Posted March 10, 2016 Lol . I might even fit the bump strips back on too . Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted March 10, 2016 I think they look odd without the rubstrips Quote Share this post Link to post Share on other sites
'Rado_TDI 10 Posted March 10, 2016 ahh mine are in the bin, could have given you some :D Quote Share this post Link to post Share on other sites
robrado974 1 Posted March 10, 2016 I think the lines of the car look cleaner without them . But I think I will be putting them back on in the future , sometime. Quote Share this post Link to post Share on other sites
