kingkenny100
Plastigauge VR6
Did you gauge your vr6 up? Im also trying to find which one is most usable for the VR too. If its the crankshaft your gauging with new bearings the standard limits are .01mm-.06mm for big end and .02-.06 for main bearing.
Sofar i cant find one which measures lower than .018mm. The red plastigauge is looking best for this as coveres .025-.175.
Ive just had my rods machined with arps. So im not sure what to go for assuming im on the tighter side of the spec.
