Will.I.Dub 11 Posted June 1, 2016 Hi guys, just got a B12 kit for my VR with plus suspension, fitting instructions say I do away with the VR springplate 357 412 341 A and use 1 H0 412 341 A. From what I can see that is the older type spring plate and presumably I need the corresponding older type top mount. Any help greatly appreciated! Sent from my D5803 using Tapatalk Quote Share this post Link to post Share on other sites
Grrrrallye 0 Posted June 1, 2016 Hi Will, I had this issue not too long ago. you just need the plate and not the mount. This is only to accommodate the larger diameter springs. VW heritage list them, but i got mine from TPS, little more expensive but quicker turn around. Alex Quote Share this post Link to post Share on other sites
Will.I.Dub 11 Posted June 1, 2016 Thanks Alex, so would that be the combination pictured below? They don't seem to sit particularly well together. I'll give it a go! Sent from my D5803 using Tapatalk Quote Share this post Link to post Share on other sites
Will.I.Dub 11 Posted June 3, 2016 (edited) So here's how it sits on the B12s Three finger gap at the front, two at the back, I will let it settle for a couple of hundred miles and see if the front comes down a little. Edited June 9, 2016 by Will.I.Dub Quote Share this post Link to post Share on other sites
Will.I.Dub 11 Posted June 9, 2016 So as grrrallye correctly says the early VR top spring plate is required. Pics for reference On left is '90 valver, center early VR and right late VR Quote Share this post Link to post Share on other sites
edd 0 Posted June 10, 2016 Despite the offset difference of the flat face the early and late VR plates don't look too different. What is the effect of using the late VR plate? Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
Will.I.Dub 11 Posted June 10, 2016 The diameter of the top of the spring is smaller in the later version, the B12 kit has a larger diameter spring despite being 'plus axle' specific Sent from my D5803 using Tapatalk Quote Share this post Link to post Share on other sites
culshaw 1 Posted June 10, 2016 I'm getting mine delivered today, so front is the early mount e.g. http://etka.cc/vw/part_single/catalog/vw/markt/RDW/modell/COR/year/1991/drive_standart/76/hg_ug/411/subcategory/102005/part_id/3705862/lang/e#sec_8 What about the rears? Did you need early rear spring discs too? (http://etka.cc/vw/part_single/catalog/vw/markt/RDW/modell/COR/year/1991/drive_standart/76/hg_ug/511/subcategory/106010/part_id/3705862/lang/e#sec_5) Quote Share this post Link to post Share on other sites
Will.I.Dub 11 Posted June 10, 2016 Bilstein fitting instructions: Sent from my D5803 using Tapatalk Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted June 10, 2016 Will.I.Dub said: So as grrrallye correctly says the early VR top spring plate is required. Pics for reference On left is '90 valver, center early VR and right late VR This explains a lot to me, i thought there was only two, the left and right one. When i tried fitted early style suspension spring i ended up with the left plate and thought it didn't work too well, so bought different suspension :lol: Quote Share this post Link to post Share on other sites
Will.I.Dub 11 Posted June 10, 2016 culshaw said: I'm getting mine delivered today, so front is the early mount e.g. http://etka.cc/vw/part_single/catalog/vw/markt/RDW/modell/COR/year/1991/drive_standart/76/hg_ug/411/subcategory/102005/part_id/3705862/lang/e#sec_8 What about the rears? Did you need early rear spring discs too? (http://etka.cc/vw/part_single/catalog/vw/markt/RDW/modell/COR/year/1991/drive_standart/76/hg_ug/511/subcategory/106010/part_id/3705862/lang/e#sec_5) The rears just slot in using all the original hardware Quote Share this post Link to post Share on other sites
Will.I.Dub 11 Posted July 24, 2016 (edited) Little update, about 500 miles after fitting the B12s the front had a 3 finger gap and the rear settled to barely two. It felt horrible on the rear, almost sitting on the bump stops all the time and a bit nose up. Weight distribution obviously felt all wrong. After a bit of research here and talking to my supplier and filling out ride height info forms for Bilstein they supplied me with a pair of replacement rear springs. From L - R first supplied spring, replacement in centre and stock on right How it sits now on 16s Great setup on the road, not at all crashy but nicely firm and planted Sent from my D5803 using Tapatalk Edited July 24, 2016 by Will.I.Dub Quote Share this post Link to post Share on other sites
diarmaid16 1 Posted July 25, 2016 Looks good. I bought a set of these and fear I will have to get replacement springs too when the time comes to fit them. Sent from my SM-J500H using Tapatalk Quote Share this post Link to post Share on other sites
seanl82 23 Posted July 25, 2016 Me too, although the ones I have fitted are the ones you had as replacements. I used SeanJaymos thread as a reference, and I've just provided part numbers and measurements to Bilstein via Demon Tweeks. Will see how it pans out....... Quote Share this post Link to post Share on other sites
Will.I.Dub 11 Posted July 25, 2016 Sean are you saying your longer spring 8502002HA has settled and the car is now lower at the rear? Quote Share this post Link to post Share on other sites
edd 0 Posted July 25, 2016 Bit of a hot topic for a few of us at the moment that bought this kit a while ago but are only just getting round to fitting. Has anyone got the measurements of the length of the faulty Spring against the length of the new spring (would the length of the faulty Spring have reduced in use, does it need to be taken before put on) Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
edd 0 Posted July 25, 2016 This is the rear Spring in the kit sat in my garage!? Is this the same part number as your faulty one? Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
GlosterOx 0 Posted July 25, 2016 Would be useful to know, what are the Part Nr's of the incorrect spring and it's correct replacement? Ian. Quote Share this post Link to post Share on other sites
Will.I.Dub 11 Posted July 25, 2016 (edited) The part number is the same but the markings are different and they're marked Eibach B/Y where yours are Eibach A/N. The numbers are incorrect spring: Eibach B/Y EW 85 13 002 HA Replacement spring they sent: Eibach KRA 90501, 85 02 002 HA, C/Q 8530 To my mind it makes a bit of a myth out of the 'matched spring & damper for your specific car' sales line. Edited July 25, 2016 by Will.I.Dub Quote Share this post Link to post Share on other sites
fendervg 33 Posted July 25, 2016 Early and late VRs had different spring lengths, even though they were both "PLUS" 5-stud wide-track suspension set-ups. Mine is a 93, and was noticeably lower than any later 94 or 95 cars I've seen, and that was on stock suspension with 35K miles on it when I bought it. If you check the parts list, you'll see that the shocks are more less the same but the springs differ in length, and the part numbers are different based on chassis number. The spring plates were then also changed - that's your mystery there - after-market suspension suppliers don't cater to this difference and only offer 4-stud or 5-stud set-ups (normal or Plus Achsel) for Corrados and Mk2/3 Golfs because it doesn't make sense for them to manufacture parts for all the variations. This is why the front spoiler also changed in height from 90 to 50 mm on later cars - customers felt the car sat too low and the spoiler was rubbing on the ground. That's my two cents input into this particular classic VW mystery anyway. Quote Share this post Link to post Share on other sites
seanl82 23 Posted July 25, 2016 (edited) This is the post I used as reference, and linked it into an email as further evidence for Eibach. http://the-corrado.net/showthread.php?80155-Corrado-Part-Duex-24V-Aqua-Blue-She-s-gone&p=1091997&viewfull=1#post1091997 I have the 3002 set fitted, but believe it should be the other spring set sent out in this link (2002). As you can see, its clearly longer. Edited July 25, 2016 by seanl82 Quote Share this post Link to post Share on other sites
Will.I.Dub 11 Posted July 25, 2016 seanl82 said: This is the post I used as reference, and linked it into an email as further evidence for Eibach. http://the-corrado.net/showthread.php?80155-Corrado-Part-Duex-24V-Aqua-Blue-She-s-gone&p=1091997&viewfull=1#post1091997 I have the 2002 set fitted, but believe it should be the other spring set sent out in this link. As you can see, its clearly longer. On the left is the original that was sent out and settled way too low, number Ew 8513002, the replacement is 8502002 Sent from my D5803 using Tapatalk Quote Share this post Link to post Share on other sites
seanl82 23 Posted July 25, 2016 Sorry for the confusion, I got the numbers mixed up. I have 3002 fitted but need 2002. Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted July 25, 2016 Glad i went with HR springs :lol: Quote Share this post Link to post Share on other sites
