Hofmiester 10 Posted June 17, 2016 Need a calliper for my mk2 which is running 280mm G60 brakes I think both 16v and Vr6 are the same but to be sure. Mine says Lucas 54 on it Anyone have one? Can't believe I need one as I chucked a pair away last year as I couldn't shift em :) Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
Hofmiester 10 Posted June 17, 2016 So apparently any VR6 54 calliper will do the job. Anyone? Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
swiftkid 1 Posted June 17, 2016 Vr6 caliper, early mk3 vr6 and gti (5 stud without the retaining clip) will be the same. Sent from my SM-G930F using Tapatalk Quote Share this post Link to post Share on other sites
Hofmiester 10 Posted June 18, 2016 Thanks! Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
swiftkid 1 Posted June 19, 2016 http://www.ebay.co.uk/itm/182152536862 This any good? Quick search in eBay, nothing to do with me. Personally I'd just go for 288mm upgrade as you could probably get a full set for cheap these days Sent from my SM-G930F using Tapatalk Quote Share this post Link to post Share on other sites
Hofmiester 10 Posted June 19, 2016 Cheers. I already have a 288 upgrade on the Corrado. This is for my mk2 with G60 brakes. Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
swiftkid 1 Posted June 19, 2016 Durrrr... Forgot to read first post again. Yea, go on eBay and search golf gti caliper and have a look through. Found a few calipers but that looked decent condition Sent from my SM-G930F using Tapatalk Quote Share this post Link to post Share on other sites
Hofmiester 10 Posted June 19, 2016 That calliper isn't the right one, it has retaining clips so it's the later one Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
Dox 31 Posted June 19, 2016 http://www.clubgti.com/showthread.php?283494-280-mm-front-brake-parts Quote Share this post Link to post Share on other sites
Hofmiester 10 Posted June 19, 2016 http://www.clubgti.com/showthread.php?283494-280-mm-front-brake-parts Sadly I can't post tithe thread on there. Cheers though Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
Guest sam1990rhodes Posted June 20, 2016 hof, just wondering how you got the 288mm brakes on the corrado? did you have to go down the 5stud route or did you manage it on a 4 stud? if so how. Quote Share this post Link to post Share on other sites
Hofmiester 10 Posted June 20, 2016 My Corrado is 5 stud (vr6) so you just swap the carriers, callipers and disks/pads Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
Hofmiester 10 Posted June 20, 2016 My golf mk2 is what I want to callipers for! :) Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
lilfuzzer 1 Posted August 3, 2016 did you get sorted ron? Quote Share this post Link to post Share on other sites
