Tobz_mw 10 Posted August 6, 2016 Looking for some rear bleed nipples for my vr6 rear calipers ASAP! Will buy the whole rear offside caliper if needs be. As close to north yorkshire as possible as needed within the next couple of days so will need to collect. Quote Share this post Link to post Share on other sites
fendervg 33 Posted August 6, 2016 They are a pretty standard VAG item. Try TPS or a dealer. They are not expensive. Quote Share this post Link to post Share on other sites
Tobz_mw 10 Posted August 6, 2016 Okay will pop down to VW on monday in that case, Thanks for the reply. Quote Share this post Link to post Share on other sites
Dox 26 Posted August 6, 2016 They're just 10mm x 1mm bleed nipples, any motor factors should stock them for around £1 each Quote Share this post Link to post Share on other sites
lilfuzzer 1 Posted August 7, 2016 have some rear calipers if you need one mate Quote Share this post Link to post Share on other sites
