robrado974 1 Posted August 13, 2016 Afternoon chaps . I'm going to take the old girl off the road and sort out the underside at the front of the car . If I enjoy the last of the weather I will be left with dark rainy evenings , which is not ideal . My question is , I obviously need to remove , track rods and the like , inc treating the subframes . Where can I lift the car from at a good height so I can work on it all ? . I have axle stands but I'm not sure where I can put them safely . This work will not be done over one weekend it will take a while . My subframes are in great Nick , I think with a clean and some treatment and paint I won't need to remove them , just change the bushes . Many thanks Rob. Quote Share this post Link to post Share on other sites
Tjninny 10 Posted August 13, 2016 Just put axle stands in front of the front suspension struts on the chassis rails - had mine like that for weeks while I had all front suspension and subframe removed. Quote Share this post Link to post Share on other sites
robrado974 1 Posted August 13, 2016 Thank you . Rob . Quote Share this post Link to post Share on other sites
fendervg 33 Posted August 13, 2016 If you look near the jacking points on the sills and then go inwards you will find a number of strengthened points on the chassis shell that you can use. Be careful to protect the top of your jack stands and jack with something (I use a rubber ice hockey puck) so as not to damage the under seal. If you do a Google search, there is a picture about of the Corrado from underneath with all the jacking points and reinforced sections marked. Quote Share this post Link to post Share on other sites
robrado974 1 Posted August 13, 2016 Great info , thanks , I appreciate it . Quote Share this post Link to post Share on other sites
