Flexso
Washer Jet replacement question??
Hi guys,
Does anyone know why there is also wires running to the washer jets aswell is the water pipe? Can they be removed? Im replacing mine tonight but the replacement have no attachements for the wires.
Thanks
You have heated water jets....not the cheapo ones unfortunately.
Sent from my SM-G900F using Tapatalk
The wires go to small contacts within the washer jets. These act as heaters and come on with the wing mirrors and rear screen when you select the rear demist button on the dash.
Less than 20 each at euro car parts where I got mine from. A lot of money still for what looks nothing. I suppose you could just leave them disconnected and fit the unheated ones. Your call really
I did a thread on repairing the heated ones if yours are faulty. I'll have a look and post it up for you. Might be of some help perhaps?
I fitted the non-heated ones and just bundled the wiring up and hid it under the scuttle near the ecu.
They can be pretty hard to remove.
