Adammcc34 10 Posted January 22, 2017 Does any one have a drawing showing the body Panels? I have started to strip my g60 project and found the panal that supports the power steering pipes has almost rotten away. So I'm looking at getting a new one. But I don't know what the panel is called. Any help would be great. Quote Share this post Link to post Share on other sites
robrado974 1 Posted January 22, 2017 Not sure of the proper name , but most of us know it as the radiator support panel . Quote Share this post Link to post Share on other sites
Adammcc34 10 Posted January 22, 2017 Not sure of the proper name , but most of us know it as the radiator support panel . Thanks. Looks like I will have to hunt one down. Quote Share this post Link to post Share on other sites
robrado974 1 Posted January 22, 2017 I've never looked in classic parts , you may be lucky ?. I got one off a mate, which was in great condition and painted it myself. Quote Share this post Link to post Share on other sites
Adammcc34 10 Posted January 22, 2017 I've never looked in classic parts , you may be lucky ?. I got one off a mate, which was in great condition and painted it myself. I saw a photo off yours. Am right in thinking it's attached to the subframe? Quote Share this post Link to post Share on other sites
robrado974 1 Posted January 22, 2017 Yes that's correct. So the front frame is removed to get to the panel . So it's not part of it , they are separate. Quote Share this post Link to post Share on other sites
robrado974 1 Posted January 22, 2017 You may as well replace the front engine mount while your at it. Quote Share this post Link to post Share on other sites
Adammcc34 10 Posted January 22, 2017 Oh ok. Is it worth getting a solid engine mount? Quote Share this post Link to post Share on other sites
Jim 2 Posted January 22, 2017 Oh ok. Is it worth getting a solid engine mount? Personally I've never seen the point of them. You get far more engine vibration into the cabin, and you're just transmitting the vibrations that the softer front mount would normally absorb, elsewhere along the front end.. so you'll wear out bushings elsewhere quicker. An uprated mount such as a vibratechnics is often regarded as a good upgrade, but would avoid a solid mount. But ultimately it's your car / your preference :) Quote Share this post Link to post Share on other sites
robrado974 1 Posted January 22, 2017 Have a look in the search , I'm not sure about solid mounts . I bought the oem part . Quote Share this post Link to post Share on other sites
Adammcc34 10 Posted January 22, 2017 Personally I've never seen the point of them. You get far more engine vibration into the cabin, and you're just transmitting the vibrations that the softer front mount would normally absorb, elsewhere along the front end.. so you'll wear out bushings elsewhere quicker. An uprated mount such as a vibratechnics is often regarded as a good upgrade, but would avoid a solid mount. But ultimately it's your car / your preference :) I was just thinking as I'm planing a stainless manifold later on. Quote Share this post Link to post Share on other sites
Adammcc34 10 Posted January 22, 2017 Ok I looked about solid mounts, it's a no from me on that. Quote Share this post Link to post Share on other sites
odub 0 Posted January 23, 2017 I have the panel you're after. This is for a 16v but i'm fairly sure they are the same part. PM me if you want to know more Quote Share this post Link to post Share on other sites
odub 0 Posted January 23, 2017 I think I have a spare Vibra Technics front engine mount too Quote Share this post Link to post Share on other sites
Geeba 0 Posted January 23, 2017 I need one too... jacked my VR up at the weekend and its completely disitigrated.... mind you it has been stood for 3+ years Quote Share this post Link to post Share on other sites
lilfuzzer 1 Posted January 23, 2017 I have some brand new mounts going spare if you want Sent from my SM-G357FZ using Tapatalk Quote Share this post Link to post Share on other sites
