Erallus
21mm vortex socket
Hi guys ,
Struggling to get hold of a 1/4 , 21mm vortex socket . Anyone know where to get one?
Basically trying to get the top nut off the strut to change the spring .
You can grind two flats on a normal socket and hold it with a suitable spanner, pass an Allen key through the middle to hold the shaft
Good shout, another thought I had was to use a cheap spark plug socket and make a hole in the plastic bit. They already have a ridged top u can get a ring spanner on
  fla said:
Get an impact wrench on it. Much easier. I've got a cheapy halfords one.
Is it a battery one?
