robrado974
Loose door handle .
Evening chaps .
I noticed today that the drivers side door handle is coming away from the door . Obviously it's a door card off job , but I can't remember what holds it on ?, I've had the door card off more times than I've had hot dinners but never for a loose handle . Easy job ?.
Kind regards,
Rob .
Check the end screw is tight first... can't remember If
The drivers side is left or right hand thread...
Good picture for removing door card on google.. sorry no link
But if you google corrado door card removal then go to pictures
It's the first picture green corrado.
Thank you Delfinis, I will take a look, by the looks of it , the job needs to be done sooner rather than later.
There should be two washers behind the screw as well. b8f087ebe229b4f7e78c2ee069ddda85.jpg
Sent from my SM-G900F using Tapatalk
I had this too, theres a plastic clip that sits in the door that you will need, that might be missing
