VR6 Lee 0 Posted November 12, 2017 (edited) I have noticed over the last few months that the humidity in my garage is around 80% which is to high for the garage so I have a feeling this is why I am getting rust bits appearing on my corrado over the years when the car is stored. Humidity levels are around the 40% mark in the house. I have put a dehumifier in the garage but still the levels are around 80% so I have just left the garage door slighly open at the bottom to get some fresh air in the garage hopefully I can get the level down a bit. Question is what does everyone else do when storing their vehicle over the winter months to keep rust at bay? Edited November 12, 2017 by VR6 Lee Quote Share this post Link to post Share on other sites
robrado974 1 Posted November 12, 2017 I have noticed over the last few months that the humidity in my garage is around 80% which is to high for the garage so I have a feeling this is why I am getting rust bits appearing on my corrado over the years when the car is stored. Humidity levels are around the 40% mark in the house. I have put a dehumifier in the garage but still the levels are around 80% so I have just left the garage door slighly open at the bottom to get some fresh air in the garage hopefully I can get the level down a bit. Question is what does everyone else do when storing their vehicle over the winter months to keep rust at bay? You could always install a humidistat fan I work in Damp proofing and plastering. I install these when working in properties with condensation problems . How old is the property?, is the garage integral ?. With all buildings as you must already know as you have stated humidity levels , you need air flow , a fan would regulate the humidity in the air . Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
dr_mat 0 Posted November 12, 2017 Outdoor humidity is practically 80+ for the whole winter. An unheated garage won't be far off the same as the outdoors, so the only way to improve it is to dehumidify or insulate or both. A fan will exchange air with the outdoor, which is currently at about 90% humidity.. You should obviously also double check for rising damp or leaks. A Corrado is for life, not just for the MOT. Quote Share this post Link to post Share on other sites
robrado974 1 Posted November 12, 2017 Outdoor humidity is practically 80+ for the whole winter. An unheated garage won't be far off the same as the outdoors, so the only way to improve it is to dehumidify or insulate or both. A fan will exchange air with the outdoor, which is currently at about 90% humidity.. You should obviously also double check for rising damp or leaks. A Corrado is for life, not just for the MOT. Stupid I phone . Even my texts fly off before I’ve finished, or is it my age ?. As I was saying is the garage separated from the house ? Can it have a gentle heat ?. A little heat and air exchange is the answer. Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
Yandards 0 Posted November 13, 2017 You could also invest in a Carcoon or similar storage system. Having used one of those for around 4 years now they make a huge difference over the winter period as the light build of rust I used to get on brake discs no longer appears. Framework style one is better for a garage just remember you need to be able to open the garage door! Quote Share this post Link to post Share on other sites
