Xto
WANTED: Show Car or Massive Spec Corrado
Hello All,
Have been a bit of a lurker since joining but have been reading a lot of threads.
i am looking for a show car or a massive speced Corrado ( turbo/ supercharged) im really looking to use the car rather than it being some garage princess.
Please can anyone selling or even thinking of selling contact me.
Thank you.
Kr,
Xto
What is your budget?
Hi,
I am more car driven than budget. So I'd rather see all cars rather than say "only cars at £x"
But I'm looking as per original post for cars where the owners have put in effort and where it's a true enthusiasts car
I have a G60 for sale....tastfully modified with no expense spared. I have receipts for £10k for just under the bonnet...bbm charger, 2 litre conversion etc etc...250+bhp!
Car has full leather, no rust and is immaculate throughout. Lots of history and receipts(folder full!).
Haven’t advertised it yet but i’ll be looking for £5.5k. Pm me if interested.
PM sent
I've got an awesome Aqua Blue Pearl with about £9k worth of mods...Looking for £5k ono.
can you upload some pictures and a bit more info of your car please?
Hello All,
Thank you.
Kr,
Xto
I've got a VRT available if you're still looking.
Spec below:
Build Thread: http://the-corrado.net/showthread.ph...l250s-VR-Turbo
M Reg Aqua Blue Pearl Corrado VR6 Turbo
160k
380Bhp, 375 lb/ft*
Outside
Paint is pretty good, could do with a couple of small patches and scratches sorting out, all panels are straight though etc
Clear Oval repeater
50mm Spliter
Red film tinted Lights
Lupo Wipers
Engine bay
Stealth Racing Stage 1+ Turbo conversion: T60/1 Turbo with Garrett internals,FMIC, chrome pipework, manual adjustable Forge recirc valve, later CP ecu and 4" MAF housing.
Rebuilt VR engine fitted approx 10k ago.
8.5:1 Headspacer, Autotech 262 cams, ARP Head and Rod bolts, Bosch Green top Injectors
All new engine sensors, thermo housing etc
Dubpower Ht leads
Complete Custom 2.5 inch Stainless exhaust system built at Stealth, no cat is fitted, doesn't sound too boomy at all.New rubber hangers fitted
Vibratechnics Rear Engine and Gearbox mount, BlackForestIndustries Front Mount. Holds everything steady with no excess vibration from cold.
Wallbro in tank fuel pump
13 row Mocal Oil cooler, new standard heat exchanger and pipes with longer bolt
New Genuine Radiator + elbow (one of the last left of each)*
Uprated Headlight Loom + Osram Nightbreaker Bulbs
Drivetrain
Racelogic Traction Control (with Launch Control) Really helps get the power down and eliminates wheelspin very subtly.
Fixed Steering column with the last fixed cowling available!
New wheel bearings front and rear,r32 wishbone bushes,*Ball joints,*Track Rod ends,*Subframe bushes,Powerflex rear axle bushes
Gearbox rebuilt by Riccardo in Leamington (they make the gearbox for Mclaren etc) and a Wavetrac LSD was fitted, new seals and bearings where needed.
Lightened and balanced Flywheel
New Helix clutch with heavy duty release arm
Audi S3 shift tower, TTweight and cables, mounted into OE Polo housing. Fits perfectly and gearshift is as good as a modern car.
Suspension/Brakes
17x7.5" Genuine BBS RC 323 alloys with Kumho KU tyres. Arguably one of the best wheels on a Corrado
10mm H&R hubcentric spacers front and rear
Weitec Hicon GT height adjustable coil overs.
Front: Porsche Boxster Brembo front callipers with standard VAG 312mm discs, Ferodo DS2500 pads. Pedal feel is really good and stopping power is great!
Rear: MKIV Golf rear Callipers with standard discs and Pagid pads
Goodridge raided front and rear lines
Weitec rear ARB
Interior
Recondtioned Standard Cream leather seats +doorcards
Black A,B & C pillars
Headunit with rear aux in
Panasonic speakers and tweeters
320mm Momo Race steering wheel
DDI backlit dials and Reverse LCD
Red LEDs in switches
New Headlight switch
New Window rollers
Chrome door pulls and pins
Silent coat sound deadening in doors pods, rears also filled with bubble wrap. Doors close with a nice thud.
EL Sheet Backlit heater controls red/blue colouring
Audi S-line Gearknob
