robrado974
Rust treatment to finishing paint , what are you chaps using ?.
Evening chaps .
As some of you may know , ive just spent 3k having all the rust cut out and repainting my car . Ive been a bit stupid , overlooked a bit of rust and forgot to tell them about it . Its on the top of the passenger door under the rubber seal. I was thinking of treating this myself as i have the paint. To be honest it does not matter what it looks like as you cannot see it once the seal goes back on . What have you chaps used and can recomend material wise ?, from treating bare steel to finishing .
Kind regards
Rob
On the work I'm doing on the underside of mine if it wasn't replaced with new metal I've taken it back to clean metal with a wire wheel removed any pitted bits with a grinding bit on a dremel if there's enough metal there then etch primer then paint
If couldn't remove the pittedness fully I have also used bilt hamber hydrate 80 then primer then paint
Sent from my SM-G935F using Tapatalk
I used POR 15 stuff and found it really good
Sent from my iPad using Tapatalk
I used eastwood rust encapsulator (not the rubberized one), high build primer, then colour, and then 2k lacquer by HB body
This is what I need to sort out .
Thanks for all your advice chaps, much appreciated
