seanl82 23 Posted March 16, 2018 As in title Gents. I only have an eazybleed at the moment and it's pants. Can anyone recommend a decent hand vacuum tool for a reasonable price? Seen the mityvac but has mixed reviews and worried it won't provide enough vacuum pressure, so any other suggestions welcome. It's not just for the Corrado so will have occasional use on others. Thanks all. :thumbleft: Quote Share this post Link to post Share on other sites
Cressa 44 Posted March 16, 2018 I use a pressure one. Sealey item I believe, and it certainly makes Bleeding brakes easier Sent from my SM-G900F using Tapatalk Quote Share this post Link to post Share on other sites
stuarttaylor37 13 Posted March 17, 2018 Another recommendation for the sealey pressure bleeder Quote Share this post Link to post Share on other sites
joebloggsVR69 0 Posted March 17, 2018 Yep, I've got a Sealey one too, great bit of kit https://www.amazon.co.uk/Sealey-VS820-Clutch-Bleeding-System/dp/B000ROARTI/ref=sr_1_1 Quote Share this post Link to post Share on other sites
seanl82 23 Posted March 17, 2018 Does that connect to the reservoir then and push fluid through like the eazybleed? My reluctance to use pressure bleeders is just that I've ended up with a reservoir with fluid full of air bubbles quite a few times now so end up spending ages draining it all and starting again Quote Share this post Link to post Share on other sites
fendervg 32 Posted March 17, 2018 Yes, it connects with a special cap on the reservoir. I've always used this model, and never had any issues once it's not over pressurised. Works much better than using the spare tyre. Your only other option is the two man gravity method I think, but that's a pain. Quote Share this post Link to post Share on other sites
seanl82 23 Posted March 17, 2018 Ok thanks all. I'll give that one a go. :thumbleft: Quote Share this post Link to post Share on other sites
Kaiser7 10 Posted March 17, 2018 The Sealey VS820.V4 won the group test in the February Car Mechanic's magazine. Can be bought for about £45 if you shop around. Sent from my Moto G (5) using Tapatalk Quote Share this post Link to post Share on other sites
VEEDUBBED 0 Posted March 17, 2018 I also have the sealy pump version, very good tool. Just remember to clean it out after use, fill the reservoir with water and pump it through the pipe, then dry it all out. If you get the Sealy vs80 model, make sure you get the angled attachment that connects to the cap, the older, straight version is limited compared because it can foul on the bulkhead of cars like Vauxhalls that have the brake fluid container recessed into the bulk head. Quote Share this post Link to post Share on other sites
1200 bandit 10 Posted May 3, 2018 I use gravity to bleed brakes,clutch systems works fine for me Get a clear tube go from the bleed nipple into a container,crack the bleed nipple then get a cup of tea Quote Share this post Link to post Share on other sites
seanl82 23 Posted May 4, 2018 I've got the sealey one as above now. Thanks for all the recommendations gents, much appreciated. :thumbleft: Quote Share this post Link to post Share on other sites
