virtuoso23 10 Posted August 1, 2018 Hey guys so still on the hunt for a intake boot for the VR as mine has tares/rips and holes all over it. Seeing as the engine is out and everything else in getting replaced might as well get to it. I did get an offer earlier in the year for a second hand good condition boot from a nice bloke on here however I never went through with it (Whoever you are "apologies") So looking around I discovered this: By HG Motor Sport - it has the ISV connection option unlike all the other after market versions for the GOLF. Anyone got any thoughts on this? Comes out a really reasonable 70 euros Quote Share this post Link to post Share on other sites
fla 9 Posted August 2, 2018 Good find. I need one without the isv connection- do they do one or does it need to be plugged? Quote Share this post Link to post Share on other sites
virtuoso23 10 Posted August 2, 2018 No, it needs to be blanked off. If you want one that comes without the ISV outlet then you have lots of choices. 42 Draft designs do a nice version for 0DB2 etc. Quote Share this post Link to post Share on other sites
fendervg 33 Posted August 2, 2018 Looks like it would have to be plugged - it's in the description. Also states that the pipe needs to be shortened for use with a standard air box. I've looked at a few of these, but most of them are made for the Mk3 2.8 VR6, where the strut tower is in a different place, meaning they won't fit a Corrado - but this one is worth a punt for the price. Quote Share this post Link to post Share on other sites
virtuoso23 10 Posted August 2, 2018 Think i'm going to take the plunge on this, especially for the price. Quote Share this post Link to post Share on other sites
Virdee 10 Posted January 15, 2019 Think i'm going to take the plunge on this, especially for the price. Did you go ahead with this. And if so did it work/fit ok? Quote Share this post Link to post Share on other sites
virtuoso23 10 Posted January 15, 2019 (edited) Hi Mate, I did indeed go ahead with this. Added the finishing touch to my rebuild. I just purchased the Aluminum intake on it's own and then two 76mm silicone extensions. Upon fitting I realised that one of the 76mm extensions was not going to give correct fitment at the throttle body end so therefore I had to buy a 45 degree elbow which I then trimmed down so that the aluminium pipe would clear the strut tower, enable correct length down towards the air feed and allow the Maf connecter plug to reach the MAF. Really works great though and sound the nuts with my cone filter. I bought the largest length filter I could find. Just to note, for the ISV connection, remove the factory plastic adapter from the hose and push straight onto the pipe. https://servi[ATTACH=CONFIG]95739[/ATTACH] Edited January 15, 2019 by virtuoso23 Quote Share this post Link to post Share on other sites
Virdee 10 Posted January 15, 2019 Perfect mate! Thanks for the speedy reply Will press the button on it and get one now! Do you have any pics or link to the 45 degree elbow you mention. As this was my only concern; clearing the strut area.... Quote Share this post Link to post Share on other sites
Virdee 10 Posted January 15, 2019 Or is this what you mean http://www.autosiliconehoses.com/silicone-polyester-reinforced-hose-76mm-45-degree-elbow-15-colours.html Quote Share this post Link to post Share on other sites
virtuoso23 10 Posted January 15, 2019 Hi mate, Any will do so long as it's 76mm See link below: That's where I got mine from. Be aware it's a b*** to get on the trottle body, but certainly isn't coming off https://www.amazon.co.uk/gp/product/B01MEH186P/ref=ppx_yo_dt_b_asin_title_o04__o00_s00?ie=UTF8&psc=1 Quote Share this post Link to post Share on other sites
Virdee 10 Posted January 15, 2019 Many thanks for all your help. Much appreciated! Quote Share this post Link to post Share on other sites
virtuoso23 10 Posted January 15, 2019 No worries mate, Upload a pic here when you've fitted and admired the new shiny intake. Quote Share this post Link to post Share on other sites
Virdee 10 Posted January 15, 2019 Will do buddy! Quote Share this post Link to post Share on other sites
Virdee 10 Posted January 26, 2019 I received this the other day. Wanted to know - Did you trim the aluminium pipe by the throttle body end? I offered it up to the car and it seemed very close to the brake fluid reservoir even with the pipe right up against the throttle body (with no silicone pile in between) Or do you have a pic from above to see how yours fits. Thanks again Quote Share this post Link to post Share on other sites
virtuoso23 10 Posted January 26, 2019 Hi mate, No trimming needed on the pipe just on the 45 degree bend a slight trim on the single piece extension hose for the MAF plug to reach. [/img] Hope that helps Quote Share this post Link to post Share on other sites
