carrots 1 Posted December 4, 2018 I changed my outer window seal scrapers a while ago with some from vw heritage. They have never seemed to fit properly. They don't push down enough onto the door so they don't touch the glass very well.also were I park I get bits off a tree getting into the door because of the gap.i also think it's the cause of my glass rattle as it didn't do it with the old ones.anyone else had same problem Quote Share this post Link to post Share on other sites
seanl82 23 Posted December 4, 2018 There is a lip on the bottom inner edge that should fold into the shape of the door. If its sitting proud, it'll keep the top edge pushed out. Its just not quite sitting correctly, so needs to be either removed and refitted, or manipulated a little bit. Do it with the window down and use a flat plastic tool of some sort to push the lower inner edge into the door whilst pushing the top of it down with your thumb. Quote Share this post Link to post Share on other sites
carrots 1 Posted December 4, 2018 Cheers I will give it a go in the daylight. I was pretty sure it was down all the way tho Quote Share this post Link to post Share on other sites
robrado974 1 Posted December 4, 2018 My drivers side is the same . Quote Share this post Link to post Share on other sites
carrots 1 Posted December 5, 2018 robrado974 said: My drivers side is the same . its not just mine then.its hard to explain but its like they are made upside down Quote Share this post Link to post Share on other sites
robrado974 1 Posted December 5, 2018 Can you put a pic up on here or the CCGB page or corrado fb page ?. Mine are new. The passenger side is perfect, but the drivers side has a gap . Quote Share this post Link to post Share on other sites
carrots 1 Posted December 5, 2018 I will try at weekend Quote Share this post Link to post Share on other sites
