carrots 1 Posted February 19, 2019 My usb stick broke the other week.ive bought a new one and put my music onto it.its working fine but if I turn the ignition off it goes back to the 1st song on the stick which does my head in.it didn't do it with the last stick.the radio is alpine ida x305 I think.cheers Quote Share this post Link to post Share on other sites
carrots 1 Posted April 25, 2019 any ideas ive even bought another usb stick and it still does it.its driving me nuts Quote Share this post Link to post Share on other sites
fendervg 32 Posted April 25, 2019 Does it need to build an index of the mp3 files on the stick in order to keep resume in memory, or maybe there's some special formatting required? Quote Share this post Link to post Share on other sites
carrots 1 Posted April 25, 2019 I haven't got a clue lol Quote Share this post Link to post Share on other sites
fla 9 Posted April 25, 2019 its not to do with the yellow and red wires by any chance is it (as for stored stations)? Otherwise is the usb format compatible (FAT)? Quote Share this post Link to post Share on other sites
fendervg 32 Posted April 25, 2019 That's a good shout - it might be losing it's memory if there is no power to it with ignition off, hence it won't know which song was playing last. Quote Share this post Link to post Share on other sites
delfinis38 1 Posted April 25, 2019 Do you loose radio stations from the memory too ? Quote Share this post Link to post Share on other sites
carrots 1 Posted April 25, 2019 ive got no signal for radio stations so not sure,the settings for bass etc don't change when I turn it off .its format to fat 32 Quote Share this post Link to post Share on other sites
carrots 1 Posted April 30, 2019 Update I've tried the red wire with yellow .it works USB as it should but radio works without key in ignition so battery might drain.ive tried red to red and yellow to yellow but it works again even without key in ignition. I've taken power from a separate wire off ignition switch, the radio works only when key is on but USB goes back to 1st song when key is off .any ideas Quote Share this post Link to post Share on other sites
fendervg 32 Posted April 30, 2019 One wire should be battery 12v+, for station memory and to run the radio without ignition, and the other should be ignition for switched live - this might only be for German style radios though. They should both be there in the wiring loom but need to be reversed for fitting some aftermarket radios. Quote Share this post Link to post Share on other sites
carrots 1 Posted May 1, 2019 I've tried switching them but both are permanent live could it be ignition switch Quote Share this post Link to post Share on other sites
delfinis38 1 Posted May 1, 2019 Can you put a volt metre on your switched positive.. I change my ignition switch due to this Quote Share this post Link to post Share on other sites
