carrots 1 Posted March 4, 2019 I noticed the plastic window rollers don't roll when I wind the wind up and down they drag in the channel.does this mean they are knackerd.cheers Quote Share this post Link to post Share on other sites
seanl82 23 Posted March 4, 2019 Could be flat spotted, but check to see if they roll freely by hand. It may be that they just need a clean and grease. If your windows rattle when wound down, chances are they're past it though. Quote Share this post Link to post Share on other sites
Guest hitoall Posted April 19, 2019 I noticed the plastic window rollers don't roll when I wind the wind up and down they drag in the channel.does this mean they are knackerd.cheers They really probably need lubrication. Quote Share this post Link to post Share on other sites
fendervg 32 Posted April 21, 2019 Easy enough to replace with some poly ones - they used to be available on here, or a quick web search will turn some up. They do need a bit of grease in the rails as well though to move freely. Quote Share this post Link to post Share on other sites
carrots 1 Posted April 23, 2019 ive got a new set to fit Quote Share this post Link to post Share on other sites
fendervg 32 Posted April 23, 2019 In that case don't bother cleaning up the old ones - just pop them off, replace, and clean and lube the rail and you should be good to go. Quote Share this post Link to post Share on other sites
