culshaw 1 Posted March 12, 2019 Hi there, I snapped a bolt out of this spacer the other day so need to source another, before i go about failing to drill it out! I need number 33 on this picture. A place to buy number 32 would be a great bonus to!o. Quote Share this post Link to post Share on other sites
1xshaunx1 27 Posted March 13, 2019 I think I have 32 and 33 in the garage. I’ll check to you at the weekend when I’m home. Thanks m after 2 off No 35, anyone know if you can get these, I’ve used a bit of pipe/hose cut to about 10mm at the mo Quote Share this post Link to post Share on other sites
Cressa 46 Posted March 13, 2019 I think I have 32 and 33 in the garage. I’ll check to you at the weekend when I’m home. Thanks m after 2 off No 35, anyone know if you can get these, I’ve used a bit of pipe/hose cut to about 10mm at the mo Regarding no.35, I have just changed my rad and replaced these. I think I may have got them from classic parts but I will check my receipts. Weirdly they seem identical to the rubbers underneath a standard VR6 Airbox Quote Share this post Link to post Share on other sites
1xshaunx1 27 Posted March 17, 2019 Culshaw. I’ve found them, I nearly gave up. Pm me your details and I’ll post them if any good to you. The bracket needs a good fettle I’m afraid. Cressa. That would be great if you could. Quote Share this post Link to post Share on other sites
Cressa 46 Posted March 23, 2019 Finally found the part number 171121276D available at VW Heritage for £1.36 each although I purchased mine from TPS Quote Share this post Link to post Share on other sites
Keyo 49 Posted March 24, 2019 (edited) I have a few of these 171121276D at home they are also used at the bottom of the airbox feet. If it is the same rubber as pictured above with the bracket the part number is 055129669 and utterley obselete . Edited March 24, 2019 by Keyo Quote Share this post Link to post Share on other sites
1xshaunx1 27 Posted March 24, 2019 Cheers guys I ordered from heritage. When looking around it’s amazing what some people want for a small rubber disk some foreign seller on eBay wants over £30 for one. https://www.ebay.co.uk/itm/WASHER-RUBBER-RADIATOR-RUBBER-WASHER-COOLANT-ORIGINAL-VW-GOLF-1990-1992-/223025839605 Quote Share this post Link to post Share on other sites
