1xshaunx1 27 Posted June 27, 2022 Don’t over tighten them bolts or the captive nuts will break loose, then it’s pretty much goosed. the seal is the o-ring as people’s have said. Try a slightly fatter top quality o-ring with some silicone grease to help it in. Quote Share this post Link to post Share on other sites
Keyo 49 Posted June 27, 2022 (edited) 16 minutes ago, 1xshaunx1 said: Don’t over tighten them bolts or the captive nuts will break loose, then it’s pretty much goosed. the seal is the o-ring as people’s have said. Try a slightly fatter top quality o-ring with some silicone grease to help it in. Thanks for the advice everyone - Ive got some oe seals coming tomorrow - i will use a bit of silicon on the seal- if it leaks after that it must be the radiator warped side so hopefully a bit of RTV will cure that if it leaks again . I will post the seal that came off and compare to the OE one. Edited June 27, 2022 by Keyo Quote Share this post Link to post Share on other sites
