nas 0 Posted May 11, 2019 As title says been offerd a brand new aeb crate engine bottom end forged with mahle 83.mm power pack pistons top end CNC'd with +1mm in out supertech valves and 3658 cat cams and tooth belt set up my question is can this engine using a g65 supercharger produce 350 bhp? Thanks for your imput Nas Quote Share this post Link to post Share on other sites
nas 0 Posted May 12, 2019 No one has a 20vg60? Quote Share this post Link to post Share on other sites
Bauhaus 3 Posted May 12, 2019 As title says been offerd a brand new aeb crate engine bottom end forged with mahle 83.mm power pack pistons top end CNC'd with +1mm in out supertech valves and 3658 cat cams and tooth belt set up my question is can this engine using a g65 supercharger produce 350 bhp? Thanks for your imput Nas No 20VG60 here, just a G60 with an extra 8v But there is a couple of people with 20V Turbos here. You’re not going to get much of a response here as most people here nowadays only speak of OEM,VR6 and part numbers.. lol Anyway not saying can’t be done but my opinion is unlikely, the G60 charger is a low pressure high flow unit and even if it’s enlarged to G65 I think it will struggle to provide enough boost to feed the cylinder head spec with a 2.1L bottom end your proposing for 350 BHP not to mention the reliability of the charger as its going to need a small pulley and spun at high RPM. Quote Share this post Link to post Share on other sites
Dox 22 Posted May 12, 2019 (edited) Mike Truluck of Jabbasport built a 20v g60 4wd mk1 scirocco many moons ago, maybe he can answer your question? Edited May 12, 2019 by Dox Quote Share this post Link to post Share on other sites
Bauhaus 3 Posted May 12, 2019 Mike Truluck of Jabbasport built a 20v g60 4wd mk1 scirocco many moons ago, maybe he can answer your question? I remember that Scirocco, saw it once back in the 90s at inters, But it was a standard 1.8 20v with 4wheel drive, 300bhp was the quoted power at the time.. if I'm not mistaken it a Scirocco Storm that he converted. Quote Share this post Link to post Share on other sites
Dox 22 Posted May 12, 2019 I remember that Scirocco, saw it once back in the 90s at inters, But it was a standard 1.8 20v with 4wheel drive, 300bhp was the quoted power at the time.. if I'm not mistaken it a Scirocco Storm that he converted. I saw it on the sprint, he got through lots of clutches because it was used hard. It had syncro running gear rather than haldex? Quote Share this post Link to post Share on other sites
nas 0 Posted May 13, 2019 Thanks for the reply Quote Share this post Link to post Share on other sites
