1xshaunx1 27 Posted June 1, 2019 I don’t know why Jon. Even with ignition off Wheatley yellow plug is plugged in or not the fans will come on. As you can see. Power to fans if low temp triggered. Quote Share this post Link to post Share on other sites
Dox 23 Posted June 1, 2019 I don’t know why Jon. Even with ignition off Wheatley yellow plug is plugged in or not the fans will come on. As you can see. Power to fans if low temp triggered. Maybe Jons sender under read so the fans didn’t run presuming a lower temp than actual temp? Open circuit and the relay assumes over temp? Quote Share this post Link to post Share on other sites
1xshaunx1 27 Posted June 1, 2019 Interesting Dox. So if he follows the photo and no light could be fan controller OR the yellow sender you say Quote Share this post Link to post Share on other sites
mattyd6892 10 Posted June 1, 2019 Thanks so much .. right did the bridging scenario ,, and there was nothing from unplugging the socket from the radiator for the fans , no spark ,,,, used some wire. Looked at the fuses and there was 19 blown and 13 which are the fans , tried again and the fans ran fine .... , replaced them and it’s fine ... runs amazing and fans kick in to cool it down !!!! Whole day out today and ran like a dream .. fans kicked In and cooled Down as should . All ran temp as should Quote Share this post Link to post Share on other sites
mattyd6892 10 Posted June 1, 2019 Indeed mate !! Quote Share this post Link to post Share on other sites
fendervg 33 Posted June 2, 2019 Great news - this shows a forum working the way it's supposed to. Quote Share this post Link to post Share on other sites
k993apc 10 Posted June 2, 2019 Mine only comes on at speed 3.never known otherwise. Bloody noisey tho Quote Share this post Link to post Share on other sites
mattyd6892 10 Posted June 3, 2019 thank guys, cant thank you all how much you have helped... putting smiles on my face again ! Quote Share this post Link to post Share on other sites
