mattyd6892
Corrado Vr6 overheating
I don’t know why Jon. Even with ignition off Wheatley yellow plug is plugged in or not the fans will come on. As you can see. Power to fans if low temp triggered.
Maybe Jons sender under read so the fans didn’t run presuming a lower temp than actual temp?
Open circuit and the relay assumes over temp?
Interesting Dox. So if he follows the photo and no light could be fan controller OR the yellow sender you say
Thanks so much .. right did the bridging scenario ,, and there was nothing from unplugging the socket from the radiator for the fans , no spark ,,,, used some wire. Looked at the fuses and there was 19 blown and 13 which are the fans , tried again and the fans ran fine .... , replaced them and it’s fine ... runs amazing and fans kick in to cool it down !!!! Whole day out today and ran like a dream .. fans kicked In and cooled Down as should . All ran temp as should
