virtuoso23 10 Posted July 30, 2019 Can a ODB1 Distributor based VR6 run fine without a lambda sensor?? Sorry if this has been answered elsewhere, searched through posts but couldn't find what I was looking for. I have just fitted a Stainless Power Sprint exhaust yesterday, I picked up used for a great price and it's in excellent condition, the original exhaust has lasted the life of the car, 27 years but was pin holed throughout. It's a bit naughty as it's designed to fit the VR6 without the cat in place. The existing lambda sensor was pretty much welded in the original exhaust so couldn't remove and fit it. Luckily the used Power Sprint exhaust has the old lambda sensor still fitted minus the wiring, so i installed it all which fitted beautifully but with a disconnected lambda. My guess is it only needs the lambda to protect the original cat and for emmission control. I took the car to work and back today and it got the best MPG readout iv'e ever had! Oh and my god the original system weighs more than a mountain Thanks Quote Share this post Link to post Share on other sites
Dox 31 Posted July 30, 2019 Without it the engine won’t run closed loop, the engine will be in limp mode to protect itself. Quote Share this post Link to post Share on other sites
virtuoso23 10 Posted July 30, 2019 Hi Dox, so it will be running permanently rich to protect it's self? Strange it got great fuel economy, although it did feel a little flat at low revs Quote Share this post Link to post Share on other sites
Keyo 49 Posted July 30, 2019 Could be wrong but couldn't this also lead to a mot fail due to emissions . Quote Share this post Link to post Share on other sites
virtuoso23 10 Posted July 30, 2019 Hi Keyo, don't worry about this, that's never been a problem :smug: Quote Share this post Link to post Share on other sites
Dox 31 Posted July 30, 2019 It should be possible to sacrifice the old boss the lambda resides inside with a grinder to weaken it to the point it can be removed. Quote Share this post Link to post Share on other sites
virtuoso23 10 Posted July 30, 2019 Hi Dox, I've ordered a new one now anyways. Was just concerned about running the car in the meantime without a lambda as im using it daily atm as my TT has gone poop, so looking for a new car. Would you expect any adverse effects running it as until the new lambda comes Much appreciated Quote Share this post Link to post Share on other sites
Dox 31 Posted July 30, 2019 Short term it should be ok, I wouldn’t do any full throttle power runs though. Quote Share this post Link to post Share on other sites
virtuoso23 10 Posted July 31, 2019 Why is that? Isn't the lambda ignored at wot though Quote Share this post Link to post Share on other sites
dr_mat 0 Posted August 10, 2019 Correct at full throttle it goes into static map relying only on knock sensors to control ignition retard. At all other times however it is relying on the lambda to trim fuelling so it will run the same way it runs after an ECU reset. This will likely be a little richer than normal operation. Don't trust the dashboard mpg.. Quote Share this post Link to post Share on other sites
Dox 31 Posted August 10, 2019 I tried to reply to the tread a week ago but the forum wouldn’t let me. Quote Share this post Link to post Share on other sites
