Keyo 49 Posted May 20, 2020 (edited) Purchased some of these - was not familar with esty but easy transaction and no need to join the site- straight payment made by paypal - UK seller £20.00 including delivery for pair. https://www.etsy.com/uk/BuckandDoeDecor/listing/798417086/vw-corrado-vr6-g60-16v-8v-3d-printed?utm_source=Copy&utm_medium=ListingManager&utm_campaign=Share&utm_term=so.lmsm&share_time=1589998755558&fbclid=IwAR3kRpTzUqZXz2Gd89aDwgPEpud_DvfIE6_gSRTm6Hc1pZ-7XMKHYz4mBik Edited May 20, 2020 by Keyo Quote Share this post Link to post Share on other sites
Cressa 46 Posted May 20, 2020 What is the fit like and do they do the job? That's what I would like to know. Glad someone has done these so I hope they are good Quote Share this post Link to post Share on other sites
Keyo 49 Posted May 20, 2020 (edited) I've purchased mine as a spare mate , they look correct no other choice apart from the phenix ones so I would grab a spare set whilst they are to be had chap. Edited May 20, 2020 by Keyo Quote Share this post Link to post Share on other sites
easypops 8 Posted May 20, 2020 I have bought a couple of pairs so hopefully they are ok 😁 Quote Share this post Link to post Share on other sites
stuarttaylor37 13 Posted May 21, 2020 On 5/20/2020 at 9:39 PM, Keyo said: I've purchased mine as a spare mate , they look correct no other choice apart from the phenix ones so I would grab a spare set whilst they are to be had chap. Ive just received a set of the Phenix ones, they look the muts!! Quote Share this post Link to post Share on other sites
tony_ack 0 Posted May 22, 2020 (edited) They're made from PLA which can start to soften at relatively low temperatures (i.e. not really suitable for a car interior due to how hot it gets on a sunny day, so probably same for the engine bay) - maybe see if the seller can do them in ABS? Or are the originals some form of Nylon? Edited May 22, 2020 by tony_ack Quote Share this post Link to post Share on other sites
Philly-R6 2 Posted October 9, 2022 Has anyone used their replacement adjusters? Are they any good? Someone else is doing them on Etsy now: VW Corrado Headlamp Adjusters 3D Printed Replacements in PETG - Etsy UK Just wondering if this is a viable fix in reality... Quote Share this post Link to post Share on other sites
Philly-R6 2 Posted November 5, 2022 Just to report back... I bought a pair of replacement adjuster bits from the chap on Etsy. It wasn't too difficult to replace the adjuster base - just fiddly. I had to split the headlight to disconnect the adjuster from the reflector (I could not get enough purchase on the barb to disconnect the adjuster using a screwdriver from behind through the bulb opening). Then I used a drift to knock the adjuster shaft from/through the handle, so I could screw the shaft into the new part. Adjuster assembly shows the parts separately. The new part is the white bit in the middle (re-using the original gromet). Once fitted, it looks like this: I've not got the headlight back in the car yet, so not sure if the adjustment range is there, but it seems ok so far... Quote Share this post Link to post Share on other sites
