will 2 0 Posted July 13, 2020 looking for a set of these if any one has any , must be good condition thanks Quote Share this post Link to post Share on other sites
Dox 31 Posted July 13, 2020 Is that what holds the pump inside the swirl pot? Quote Share this post Link to post Share on other sites
vw rule 19 Posted July 13, 2020 36 minutes ago, Dox said: Is that what holds the pump inside the swirl pot? Hi Dox, yeah kind of the 3 item's in question attach to the cradle bracket and help it to remain fixed to underside of car once bolted up. Si Quote Share this post Link to post Share on other sites
vw rule 19 Posted July 13, 2020 4 hours ago, will 2 said: looking for a set of these if any one has any , must be good condition thanks Hello there, I can't promise anything but I might have a few spare, but possibly only of the black rubber mount buffer's and the metal safety speed nut clips, the round metal compression spacer sleeves I've only got the one new set, that I've used on my new set up. The black rubber mount buffer's are part number 191 201 274 (I might have some of these) ?? The metal safety speed nuts are part number 191 201 280A (I might have some of these) ?? The round metal compression spacer sleeves are part number 191 201 278A (I'm 95% sure I don't have any of these spare unfortunately) But will check. I'll have a look tomorrow in my spares and see if I've got any of the item's in question. Si Quote Share this post Link to post Share on other sites
fendervg 33 Posted July 14, 2020 Are these fittings not for the black plastic fuel filter holder on the underside of the car ( only fitted on some models)? The swirl pot sits inside the tank and slots into a bayonet type mount on the tank floor, or so I thought. Quote Share this post Link to post Share on other sites
will 2 0 Posted July 14, 2020 17 hours ago, vw rule said: Hello there, I can't promise anything but I might have a few spare, but possibly only of the black rubber mount buffer's and the metal safety speed nut clips, the round metal compression spacer sleeves I've only got the one new set, that I've used on my new set up. The black rubber mount buffer's are part number 191 201 274 (I might have some of these) ?? The metal safety speed nuts are part number 191 201 280A (I might have some of these) ?? The round metal compression spacer sleeves are part number 191 201 278A (I'm 95% sure I don't have any of these spare unfortunately) But will check. I'll have a look tomorrow in my spares and see if I've got any of the item's in question. Si hi , if you have the speed clips i mite be able to salvage my rubbers, thanks Quote Share this post Link to post Share on other sites
vw rule 19 Posted July 14, 2020 11 hours ago, fendervg said: Are these fittings not for the black plastic fuel filter holder on the underside of the car ( only fitted on some models)? The swirl pot sits inside the tank and slots into a bayonet type mount on the tank floor, or so I thought. Hello mate, yeah these 3 item's in question are fitted to the 8v 16v MK2 Golf GTi, the 16v Passat, and the 16v's & G60 Corrado's. The Corrado 8v & VR6 only have the one fuel pump in fuel tank so these fixings are not used on this setup. All the others listed above have 2 fuel pumps so need these fixings, for the fuel swirl pot cradle support bracket. Si Quote Share this post Link to post Share on other sites
vw rule 19 Posted July 14, 2020 (edited) 5 hours ago, will 2 said: hi , if you have the speed clips i mite be able to salvage my rubbers, thanks Hello there, right I've had a good look through my spares and have got some new black rubber mount buffer's, and new metal safety speed nuts. I've double checked regarding the round metal spacer sleeves, but don't have any of these spare I'm afraid. Let me know if you want both item's for £15, this is for x4 rubber mount buffer's & x4 safety speed nuts. or just the x4 safety speed nuts for £4 Si Edited July 14, 2020 by vw rule Quote Share this post Link to post Share on other sites
will 2 0 Posted July 14, 2020 7 minutes ago, vw rule said: Hello there, right I've had a good look through my spares and have got some new black rubber mount buffer's, and new metal safety speed nuts. I've double checked regarding the round metal spacer sleeves, but don't have any of these spare I'm afraid. Let me know if you want both item's for £15, this is for x4 rubber mount buffer's & x4 safety speed nuts. or just the x4 safety speed nuts for £4 Si hi thanks for finding them, yes i'll have all those off you, shame about the sleeves though. pm me your paypal details and i will sort that out for you Quote Share this post Link to post Share on other sites
vw rule 19 Posted July 14, 2020 30 minutes ago, will 2 said: hi thanks for finding them, yes i'll have all those off you, shame about the sleeves though. pm me your paypal details and i will sort that out for you I've sent you a PM. Many thanks Si Quote Share this post Link to post Share on other sites
will 2 0 Posted July 15, 2020 7 hours ago, vw rule said: I've sent you a PM. Many thanks Si PM sent mate Quote Share this post Link to post Share on other sites
vw rule 19 Posted July 15, 2020 5 hours ago, will 2 said: PM sent mate Many thanks for payment your item's have been sent out, you should receive them in the next 2 to 3 working days. PM reply sent also. Thanks again Si Quote Share this post Link to post Share on other sites
will 2 0 Posted July 15, 2020 7 minutes ago, vw rule said: Many thanks for payment your item's have been sent out, you should receive them in the next 2 to 3 working days. PM reply sent also. Thanks again Si Thanks again. Quote Share this post Link to post Share on other sites
vw rule 19 Posted July 19, 2020 On 7/15/2020 at 1:46 PM, will 2 said: Thanks again. I've had another good look through my spares just in case, but definitely don't have any spare of the metal spacer sleeves you need. I've found something similar on Ebay and they sell the spacer sleeves in different sizes, so you might be able to get some hopefully that will fit yours, I'll put a link up below for you to have a look at. https://www.ebay.co.uk/itm/132812282714 Hope this helps Si Quote Share this post Link to post Share on other sites
will 2 0 Posted July 19, 2020 (edited) 9 hours ago, vw rule said: I've had another good look through my spares just in case, but definitely don't have any spare of the metal spacer sleeves you need. I've found something similar on Ebay and they sell the spacer sleeves in different sizes, so you might be able to get some hopefully that will fit yours, I'll put a link up below for you to have a look at. https://www.ebay.co.uk/itm/132812282714 Hope this helps Si hi Si just to say i recived all the parts thanks, managed to buy a length of pipe same dimensions from b&q just got to cut it down to the size of the OE ones. Edited July 19, 2020 by will 2 Quote Share this post Link to post Share on other sites
vw rule 19 Posted July 19, 2020 3 minutes ago, will 2 said: hi Si just to say i recived all the parts thanks, managed to buy a length of pipe same dimensions from b&q just got to cut the length down. Hello mate good to hear your parts arrived safe and sound, no worries 👍 Oh fair play on the tube good shout that should work 👍 Many thanks Si Quote Share this post Link to post Share on other sites
will 2 0 Posted July 19, 2020 2 minutes ago, vw rule said: Hello mate good to hear your parts arrived safe and sound, no worries 👍 Oh fair play on the tube good shout that should work 👍 Many thanks Si going to put a post up in a bit of the repair i done on the swirl pot in the drivetrain section Quote Share this post Link to post Share on other sites
vw rule 19 Posted July 20, 2020 10 hours ago, will 2 said: going to put a post up in a bit of the repair i done on the swirl pot in the drivetrain section I've just seen it, top quality repair 👍 Si Quote Share this post Link to post Share on other sites
fla 9 Posted July 20, 2020 That looks pretty impressive! Quote Share this post Link to post Share on other sites
